6 hours ago, Starletson said:
Thanks guys 🙂
Rust and paint need sorting next
Get your wallet out mate i feel your pain
  • Replies 93
Posted Images
12 hours ago, Goldie said:
Just been reading through this, nice build dude, keep it up. What's next?
Probably need to sort out the paintwork, the passenger door is getting bad on the bottom corner and the rest of the car is in need of some tlc.
Rear drums and front calipers could do with a lick of paint, so could some engine bay brackets.
Glanza front brakes would be a nice addition, may just upgrade these original discs and pads when the time comes.
Rear wheel bearings need doing and the rear shocks may need replacing
Got some 303 to spray on the rubbers
Need to clean the grime off the side of engine as I'm getting some belt slippage and the annoying sqweek
I've replaced all the headlight bulbs with some phillips ultra white aswell
May take a wire wheel to the rocker cover and see how that turns out
Edited by Starletson
More content
  • 3 weeks later...
On 3/4/2022 at 1:21 PM, Starletson said:
Intake on 😁
Was that a straight bolt on? Videos and other posts I seen you had to mess around with the throttle cable and putting in washers for it all to fit etc but it looks the same as standard in this pic
  • 3 weeks later...
  • 1 year later...
  • 1 month later...
Didn't get the bits in the end, weather was shite and flooded roads etc. Getting her MOT'd soon. Can anyone confirm if I need Glanza calipers to upgrade the front brakes? Or just the pad carriers?
  • 4 months later...
She looks sad 😪
Finally got a passenger door! Just need to fit it 🤣 que wonky door 🤪
Been in for new discs and pads and had rear bearings done. In for MOT on 2nd Sept 🤞🏻
What would be the pros/cons plus parts required to turbo the 4e versus chucking a 5e in her? Does the 5e just need the engine and a 5e engine management and bobs your uncle?
