Got a bit more done , need to collect 2nd hand bonnet to line up and check fitment before I weld in new crossmember.
Some weld through primer added then trail fit of crossmember 😀
  • Replies 54
Posted Images
Start of engine mods began also ,beginning with det3 with plug and play loom. Followed with standard turbo manifold with restriction removed from cylinder 3 runner. Then fitted one of my spare glanza power steering pumps along with pipes and brackets
On 5/23/2021 at 9:56 AM, Sam44 said:
Go on mike. Starbo time. What turbo are you thinking of running?.
I'll get them flaps upto you soon.
Just a ct9 I had lying about which I've had Midland turbos refurb it
On 5/24/2021 at 7:03 PM, Dale SR said:
Good work, I'm looking forward to seeing another SR on the roads in Scotland!
So am I 😃
Bit more time spent preparing for turbo fitment which included removing one rather crusty sump . For replacing with a spare turbo sump and matching pickup pipe
Then it was time for the drilling of the block for the 4efte oil filter housing. Must admit I wasn't looking forward to this. 😦
Took me a minute to suss out what was going to be the best way of drilling these. And decided to insert copper pipe into filter housing holes to act as a guide to drill straight holes for studs.
Also measured depth of one of my turbo block holes which was approx 23mm. So checked threaded part of studs that were being fitted approx 13mm . Decided I didn't need to go as deep as oe . So settled on 19mm depth for clearance used a bit of tape on drill bit for depth gauge. Worked well just need to open them out and tap them tomorrow 🙂👌
More progress , although it is kind of a backward step at the same time🤦‍♂️
Firstly finished off where I left off with tapping the holes for the oil filter housing
Ok so my ocd kicked in , the inner wing at the passenger side was annoying me . While I was repairing the recent crossmember damage the inner wing was annoying me . So gluten for punishment I cut this front end off a local car . So that decided I was replacing inner wing , slam panel and complete crossmember also 😲
3 hours ago, Dale SR said:
The badge is from a Reflet Starlet , There really smart :)
Is the rest of the starlet you got the bonnet from breaking somewhere ?
Lad that I got the bonnet and cut from swapped out the front on the reflex for glanza parts it's also forged and turbo
Almost ready to weld on front section now which includes chassis leg and inner wing at n/s/f. Which was from a previous repair that I wasnt keen on. It's been alot of work and hours already but hopefully have the front end ready for paint. I will let the pictures do the talking
Bit more final tweaking and alignment checks along with trail fitting wings and bumper before welding it all up , thank god
Front end mocked up and all gaps checked ready for welding on for good 😎
All joints zinc primed with weld through primer. Pretty happy with the alignment
On 6/8/2021 at 11:32 AM, Dale SR said:
Nice to see her back in one piece, I look forward to seeing her painted 😀 great work!
Cheers
So do I 🙂
Well finally got the front end fully welded up . Just need to smooth off and blend in welds before seam sealer is applied. Then onto mocking up radiator and intercooler setup 😀
  • 3 weeks later...
