BearFaceOfDoom Posted October 31, 2010 Posted October 31, 2010 Sorry but am I the only one that finds this hilarious?! ! ! The brake is the important preservation part. Because it is the part which relates to life,You recommend that it does at the shop and the maintenance shop etc which have technology to installation.As for the one which does not have self-confidence please make sure not to handle under any condition.The one which has self-confidence on self responsibility the action,Before travelling, be sure to inspect the public road! ! ! Quote
bongskag Posted June 16, 2012 Posted June 16, 2012 it makes sense thoi like this one ,"As for the one which does not have self-confidence please make sure not to handle under any condition."if you dont know what your doing dont touch it ! lol . Quote
5e colin Posted September 13, 2013 Posted September 13, 2013 hey guys i just got miselve the levin bzr twinpots ( 97) i searched a good while now to no avail is there disks available that dont require spacers ???? dont mind disk being worked on , but dont want to use extended wheel nuts because the wheel will just be attached to 4 bolts and not resting on the hub theres loads of info on the celica setups!!!! Quote
rob_bower Posted September 14, 2013 Posted September 14, 2013 From what I recall when I looked in to it it's the disk from a mk4 Astra diesel. They just need 1mm shaving off the inside of the bell. Iirc. It's been a while though. Hopefully someone else can confirm. Quote
pockrockgtti Posted September 14, 2013 Posted September 14, 2013 And you need some spigot rings to reduce the center bore of the astra disc from 60mm to 56.1mm From what I recall when I looked in to it it's the disk from a mk4 Astra diesel. They just need 1mm shaving off the inside of the bell. Iirc. It's been a while though. Hopefully someone else can confirm. Quote
5e colin Posted September 14, 2013 Posted September 14, 2013 (edited) From what I recall when I looked in to it it's the disk from a mk4 Astra diesel. They just need 1mm shaving off the inside of the bell. Iirc. It's been a while though.Hopefully someone else can confirm. thanks man / do them diesels only come in 1 disk size for all the diesel cc engines ???? maybe a part nr for the disks is that the astra G model??? 1.7 diesel Edited September 14, 2013 by 5e colin Quote
Ryannnnjames Posted January 22, 2014 Posted January 22, 2014 HELP ! Hi I believe I have levin upgrades , bought my V a few months ago and got some spares too including 4 hubs and calipers and last month my wheel bearing went so just thought I would change the hub to save abit of money and then when doing this the brakes that were on already wouldn't for on the spare hubs I had as the wheel nuts weren't long enough so if I'm going to get a new wheel bearing would I get a levin wheel bearing or is it simply just longer wheel nuts put on original hubs! Quote
morgey Posted January 22, 2014 Posted January 22, 2014 Standard starlet wheel bearing. Longer studs, just remove the studs from the old hubs Quote
5e colin Posted October 3, 2015 Posted October 3, 2015 just to ad to this thread i did it few years back and got the """" APEC DSK 2188 """"" al i had to do was cut 1.5mm of the inside hubface ( 4x100 ) and cut them down to 260mm now they bolted strait onto my hub without spacers and longer studs pure oem fitment they also fit under my 14" jdm wheels Quote
morgey Posted October 3, 2015 Posted October 3, 2015 Use st202 celica gt carriers and you can use 275mm discs with levin twinpots Quote
Turbo Goose Posted March 30, 2016 Posted March 30, 2016 So what discs everyone running?Ive currently got astra cdti discs on my single pot conversion would the levin twin pot be a direct fitment onto the carrier? Quote
morgey Posted March 30, 2016 Posted March 30, 2016 Quite possibly, are the singles off a celica if so what year? Quote
tommyep82 Posted April 4, 2016 Posted April 4, 2016 What disks are 275mm?, I can get st202 carriers and Levin twin pot calipers Quote
morgey Posted April 5, 2016 Posted April 5, 2016 Astra discs mentioned above are 277mm. Dont require spacing but need a spigot ring.Levin discs are 275mm but require spacing out about 4mm to center them innthe caliper Quote
tommyep82 Posted April 5, 2016 Posted April 5, 2016 Ok thanks so would I need Celica st202 pads or are gt4, st202 and Levin pads all the same? I'm finding it hard to find a company with decent pads that will actually reply to my email, Quote
morgey Posted April 5, 2016 Posted April 5, 2016 I had a look laat night for someone else regarding this. The correct pads would be st202 but the dimensions for all were very close.St202 celica 141x63x17Ae111 Levin 141x57x15Sw20 Mr2 141x57x15 Quote
tommyep82 Posted April 5, 2016 Posted April 5, 2016 And just one more question will 15 inch wheels fit under the Celica carrier with the 275 disks Quote
morgey Posted April 5, 2016 Posted April 5, 2016 Dude you need to read the thread some more 😜Use st202 celica gt carriers and you can use 275mm discs with levin twinpotsWould they fit under 15 ok?Got them under my 15" sr speedlines Quote
