keirz Posted May 19, 2009 Posted May 19, 2009 sorry guys but to be fair if thats what you are looking for why dont you just buy a td04 hybrid and td04 mani or an adaptor to fit the ct9 mani's? the idea is this rivals the td04 kits other wise its just a td04 that fits ct9 mani's dont get me wrong im not having a go by any means just saying it defeats the idea of a ct9 hybrid im soo desprate to take one off your hands when the kits are ready finally got to the bottom of my boost problems and it turnred out to be my hybrid lol the internal gate had opened slightly so if i had just bloody tested this it would have fixed the problem lol oh well.disagree fully mate.basically a few reasons, one being most people will already have upgraded ct9 mani and decat, so using the td04 compressor end on the ct9 turbine housing would be ideal and cost effective. the other thing your missing and this is the main one, using the td04 compressor end with the ct9 turbine housing would create a turbo so different to a standard td04. its charicteristics ( my spellings shit sorry) would be completely different. you would have the higher air flow and compression from the tdo4 compressor end, also lower intake temps due to the more free flowing compressor snail at your chosen boost level. as the ct9 one is much smaller than the td04 (again safer and better power), without having the added lag from the td04 bigger a/r turbine housing.meaning you can have a more responsive turbo capable of creating power close to that of a td04.not trying to make an argument just explaining the reason why it would be better, reasons which you missed or was unaware of.
shorty Posted May 20, 2009 Posted May 20, 2009 i stand corrected bud sorry i hadnt realised it would make such a difference. and dont worry it wont start an argument after all every day is a school day when it comes to starlets.
keirz Posted May 21, 2009 Posted May 21, 2009 no worrys mate. ive been doing a lot of research at work into the best combinations and the most restrictive areas of the ct9 and i find what was described above (as long as the boost can be controlled) would be immense on a 4efte
Sanchez Posted May 25, 2009 Posted May 25, 2009 i cant wait for these to be finished will deffo be buying the kit
Guest Enzo Posted June 1, 2009 Posted June 1, 2009 yea, keith is just in the process of getting a batch of manifolds and decats made up,im just in the middle of getting a batch of custom lines made up from purtek which i shold be picking up on wednesday, im not cutting corners on the lines so the water lines will be front mounted instead of using banjo boltsthe full kit will retail for £1150the turbo with oil and watelines will retail for £650 wich still represents good value compared to other hybrids as you can sell your current unit.you can pre order now i will be hooking mine up as i have all the parts ive just been set back as the girlfriend put diesel into the v that im gona be using to test it on over the weekend.
WallaceGlanza Posted June 1, 2009 Posted June 1, 2009 Sounds good mate I'm really looking forward to getting one of these and have pretty much everything needed to run one now. Are you still needing the thermostat housing?
Sanchez Posted June 1, 2009 Posted June 1, 2009 Think i will be getting this kit i want to try this as its different from the td04 routewill it preform better???what power will it make on a forged engine, management and supporting mods???and the kit dosent include wastegate or ic??cheers
Guest Enzo Posted June 1, 2009 Posted June 1, 2009 @ wallace possebly dude, im gona take my one off the silver v tomorrow, if i cant manage that for some reason thne il hollar at you for yours @ sanchez it will get to a bar a full 1-1.5k quicker than a tdo4 so low to midrange will be lethal. its also raited for more boost compared to a normal ct9 hybridi cant coment on the power yet as im still waiting on dyno figures from two members. but the only tester who tested both gt spec and this back to back said its leagues ahead of the gt spec.your questions have been answered further up this post but going over it againthere are two many waistgates to choose so il leave that up to the buyer.the full kit which will include oil return/braded feedall gasketsbraded water linesmanifold decattd12 ultimate
Sanchez Posted June 1, 2009 Posted June 1, 2009 ah ok mate sorry misread it.ooo i cant wait for these to be done i will be in touch
Guest Enzo Posted June 2, 2009 Posted June 2, 2009 from keithIts made for 38mm wastegates, but if you got other size thats smaller, it goes on no problems. Ideally its for 38mm though as the width on the flange is measured for that size.
monka Posted June 2, 2009 Posted June 2, 2009 enzo, would you need to modify the turbo - down pipe gasket to fit this? as the exhaust wheel is so much bigger, surely if you put a standard one on, it will protrude into the line of the turbo flow,???? say if i used this on a different external gated kit
Guest Enzo Posted June 2, 2009 Posted June 2, 2009 no monka you dont need to modify the downpipe gasket
Miller_Ep91 Posted June 2, 2009 Posted June 2, 2009 any pics of thre finished item . the complete kit?
Ryan Posted June 3, 2009 Posted June 3, 2009 Yeah enzo how much would the kit be without the decat as i have a blitz one here pm me if you want
shorty Posted June 13, 2009 Posted June 13, 2009 any update on when these can be purcahsed? and dont supose you can supply the already rotated can you?
RobSR Posted June 14, 2009 Posted June 14, 2009 about everyone saying they can use there "standard fitment" ct9 decat will have to be confirmed with keith/geo, as if the mani holds the turbo in a different position to stock, the DP aint gonna fit
Guest Enzo Posted June 14, 2009 Posted June 14, 2009 the down pipe will fit fine so people can use there standard fitment decats.i wont be able to rotate the housing on the turbo shorty@ Ryan i will post pics and prices up when we have a few kits ready,i will also get the testers to post some feedback on these tubbys, they are up and running now and looking mint,il also be doing some bench testing on this and the gt spec within the coming week,in regards to when they will be available, tong turbo and zisco are building up stocks the now.we are real close guys.
