abbott Posted July 29, 2009 Posted July 29, 2009 this is a not a for sale thread just wondered if i would get much interest in parts if i desided to strip as much as i dont want to.PLEASE SEE MY MEMBERS GARAGE IF YOU DONT KNOW MY CARENGINE (*COMPLETE*)ROB BARNARD SPEC ENGINE (SES ENGINEERING)4E-FTE *Wossner Forged Pistons *Wossner Forged Rods *Fully Balance Bottom End *Gas Flowed and Polished Head *2mm Cruise Head Gasket*Light Weight Crank Pully*Ported and polished inlet manifold to match head *NGK Iridium Plugs (Heat Range Cam cover with custom braided line and oil catch can Sard 550cc Injectors Sard Fuel Pressure Regulator with Custom Braided FPR Lines Walbro Uprated Fuel Pump Custom Custom Oil Cooler and Braided Lines Magnecor 8.8mm Leads TURBO KIT (*COMPLETE)*Custom Ricky Lee manifold *Custon Hard Intercooler Pipework *Custom Front Mount Intercooler *Custom Braided Turbo Oil Line*Custom Braided Turbo Water Lines*Custom Front Exit Exhaust (heat wrapped)*Custom Air Filter Pipe*HKS GT25/30 Roller Bearing Turbo With Steel Turbine *HKS Mushroom Air Filter *HKS SSQV Blow Off Valve *HKS Actuator MANAGEMENTGreddy emanage ultimate with main, injector and ignition harnessesGreddy emanage 3bar pressure sensorGreddy knock sensor adaptorField harness DRIVETRAIN Standard Gearbox with TRD LSD TRD Quickshift Exedy Organic Clutch Custom Braided Clutch Line CHASSIE/SUSPENSION TRD engine mounts BC Coilovers Front Strut Brace Rear Strut Brace Cusco lower arm bar Whiteline Front Anti-roll bar + Whiteline Drop Links Whiteline Anti-lift/Castor Kit Whiteline Adjustable Panhard Rod Whiteline Rear Anti-Roll bar BRAKES, WHEELSWilwood 4 pot Brake Kit standard rear discs, pads and bearing ALMOST NEW MR2 15" wheels powder coated mat black with Yokohama Parada Spec-2 Tyres Carbon Cooling Panel Greddy Profec B Spec 2 boost controller Greddy Turbo timer 3 point harnesses rolling Mk1 Shell with complete interior windows, loom, doors, Boot, dash ect Quote
LukeSR Posted July 29, 2009 Posted July 29, 2009 Im interested in the front and rear strut brace (If they fit the EP91??) Quote
cleanshavenllama Posted July 29, 2009 Posted July 29, 2009 interested in rear arb and panhard rod if they fit the ep91 Quote
5T4R7ET N/A Posted July 29, 2009 Posted July 29, 2009 im intrested in the rear arb and trd quick shift Quote
Liam_D Posted July 29, 2009 Posted July 29, 2009 I would be interested in the rear brace aslong as it would fit a EP91? Quote
adee-ep Posted July 29, 2009 Posted July 29, 2009 give me a pm and let me no how much you want for the turbo kit? Quote
Kennedy Posted July 29, 2009 Posted July 29, 2009 be interested in the gearbox and drive shafts. Quote
Sparky Posted July 29, 2009 Posted July 29, 2009 Theres so much I want but I am genuinely interested in the BC's, PM me a price Quote
Guest dominodon Posted July 29, 2009 Posted July 29, 2009 Price for the Whiteline Front Anti-roll bar + Whiteline Drop Links Pm meThanks Quote
abbott Posted July 30, 2009 Author Posted July 30, 2009 Replyed and pmd most got to do some more Quote
5T4R7ET N/A Posted July 30, 2009 Posted July 30, 2009 can you pm a aprice for the trd quick shift and the rear arb. thanks! Quote
Wee_Watsi Posted July 30, 2009 Posted July 30, 2009 Could you pm me a price for the Sard Fuel Pressure Regulator please. Very interested.Thanks,Watsi Quote
LukeSR Posted July 30, 2009 Posted July 30, 2009 By the way, if your selling the front seats drop me a PM Quote
