Amjad Posted January 22, 2011 Posted January 22, 2011 HeyI know this question's been asked loadsa times but I just need a quick list of what I'll require to run 1Bar CT9 on my Mine's ECUCurrent Spec:-NGK Iridium Heat Range 7 Plugs-Ported wastegate CT9a-Ported OEM manifold-Gutted OEM Cat-HKS Actuator-Relocated filter-Air con removed-Fujitsubo 2.25" exhaust-Mine's Plug & Play ECUWill be buying:-2.5" Exhaust-FMIC-TD uprated fuel pumpShould I buy?-An aftermarket exhaust manifold-A proper 2.25/2.5" decat-Uprated HT Leads-Race Tech Braided oil feed/returnI'm not sure if there's anything else I need? Obviously wanna do it as cheap as possible because this is only temporary, wanna eventually run TD04 @ 1BarAmjad Quote
ryan lang Posted January 22, 2011 Posted January 22, 2011 id deffo get an aftermarket mani dude Quote
_shaun_ Posted January 22, 2011 Posted January 22, 2011 def a race-tech braided oil feed/return imo then after that just what funds u have Quote
Steve GT Posted January 22, 2011 Posted January 22, 2011 everything you have stated id deffo do mate its worth it in the long run ;) Quote
ro55ifumi Posted January 22, 2011 Posted January 22, 2011 def a race-tech braided oil feed/return imo then after that just what funds u haveFirst Thing i would do^^^^^^ then Boost Controller?? Quote
lukEp Posted January 22, 2011 Posted January 22, 2011 I've been running a ported mani for 12months now when doing the porting I had a jam mani to copy ;) and it's been 100% so far. You will find gains from de-cat as even the gutted cat has restrictions in it as I found. But this is not essential. Quote
Asad Posted January 22, 2011 Posted January 22, 2011 no need for the fuel pump unless your going over 200 (alot of peeps go anal as if its a must need item...not really)boost gauge?wouldnt 2.5" be big for the CT9? Quote
Socks Posted January 22, 2011 Posted January 22, 2011 oil catch tank is wise... these engines breath havily at high boost and spit oil out a normal breather so saves the mess!and a boost controller is a very good idea to try n help with boost creep! Quote
Sparky Posted January 22, 2011 Posted January 22, 2011 I would deffo get a decent manifold and decat.You got most bases covered dude, but a EBC is a must for decent boost control ;)Will be a rapid little car Quote
Fro Posted January 22, 2011 Posted January 22, 2011 I wouldnt bother with a manifold, if its well ported it will do the job more than well enough and probably less likely/ cheaper to replace than an aftermarket one if/when it cracks.I wouldnt be too worried about the 2.5" exhaust either but you might notice a little difference with a proper decat.As above you would probably benefit from an ebc and you might need a rrfpr but you would find out once you got your fueling checked.Id recommend a braided oil reed cause the oem ones are ghey! Im not sure how much racetech ones are but you would get your own one made cheap enough but all depends if you can be arsed!I couldnt comment on whether or not a fuel pump is essential Quote
Pandamonium Posted January 22, 2011 Posted January 22, 2011 Dont sweat the manifold mate:http://www.ukstarletclub.com/forums/index....0&start=180 Quote
Amjad Posted January 22, 2011 Author Posted January 22, 2011 Lots of advice there guys thanks!I've been running a ported mani for 12months now when doing the porting I had a jam mani to copy and it's been 100% so far. You will find gains from de-cat as even the gutted cat has restrictions in it as I found. But this is not essential.Dont sweat the manifold mate:http://www.ukstarletclub.com/forums/index....0&start=180Sounds like I should be okay for a while with the mani, I can see how an aftermarket one may give a few more horses but they are quite pricey. I don't wanna buy a CT9 manifold because it would be useless when I go TD04. Here's some pics of the porting:I think the boost is a bit unstable because of the gutted cat so I'll look for a proper decatno need for the fuel pump unless your going over 200 (alot of peeps go anal as if its a must need item...not really)boost gauge?wouldnt 2.5" be big for the CT9?Yep I have a boost gauge, didn't have the T-Piece to plumb it in but I have one know, will be fitted when I'm next homeI reckon 2.5 inch is perfect, most aftermarket ones are 2.5"+ and it'll be sufficient for TD04 too oil catch tank is wise... these engines breath havily at high boost and spit oil out a normal breather so saves the mess!and a boost controller is a very good idea to try n help with boost creep!Cool I'll keep an eye out for a catch tank, should they have a bleed screw on the bottom or a removeable top? And a breather on top rather than being airtight?I would deffo get a decent manifold and decat.You got most bases covered dude, but a EBC is a must for decent boost control Will be a rapid little carIn terms of a boost controller, they seem to be quite expensive I've done a bit of reading on here and it seems a Dawes device/Turbosmart boost controller offers a lot of the advantages of an EBC at a fraction of the price?MBC thread 1MBC thread 2I wouldnt bother with a manifold, if its well ported it will do the job more than well enough and probably less likely/ cheaper to replace than an aftermarket one if/when it cracks.I wouldnt be too worried about the 2.5" exhaust either but you might notice a little difference with a proper decat.As above you would probably benefit from an ebc and you might need a rrfpr but you would find out once you got your fueling checked.Id recommend a braided oil reed cause the oem ones are ghey! Im not sure how much racetech ones are but you would get your own one made cheap enough but all depends if you can be arsed!I couldnt comment on whether or not a fuel pump is essentialOkay by the sounds of it I probably won't need a fuel pump until I go TD04?I'll be on the lookout for a braided oil feed. Are used ones okay? Trying to keep the costs down lol ;) Quote
Sparky Posted January 22, 2011 Posted January 22, 2011 You pay for what you get when it comes to EBC's mate With mine I can adjust how much boost every 500-1000rpm and how much boost I want in each gear Quote
Amjad Posted January 22, 2011 Author Posted January 22, 2011 Maybe something to get in the future, for know what would you suggest in terms of MBCs?I hear controllers don't make a difference on creep, they just bring in boost earlier? Quote
BAZ2CRAZY Posted January 22, 2011 Posted January 22, 2011 Ive got a full exhaust including de-cat you can have for £150. WEPR too, sounds cool.See here;http://www.ukstarletclub.com/forums/index....showtopic=35580Mitch Quote
Amjad Posted January 23, 2011 Author Posted January 23, 2011 Can someone read over post #12 please? Quote
enots Posted January 23, 2011 Posted January 23, 2011 i've got a dawes device MBC on mine seems to do the job pretty well never had any issues with it man Quote
Amjad Posted January 23, 2011 Author Posted January 23, 2011 Cool, any idea where I can get one and how much I should pay?Should I get a fuel pump for 1Bar on CT9? Quote
Asad Posted January 23, 2011 Posted January 23, 2011 iirc nightspirit ran a MBC GReddy one infact Quote
BAZ2CRAZY Posted January 23, 2011 Posted January 23, 2011 Change the fuel pump for 255lph.Get a HKS actuator if you haven't already.Mitch Quote
Amjad Posted January 23, 2011 Author Posted January 23, 2011 I've opened another thread about MBCs hereYeah got a HKS actuator set at fuel cut! I've got a J Performance Decat now and a braided oil line, wanna go ahead and get exhaust, FMIC before getting fuel pump and wacking it up a Bar! Quote
