TheStarletGT Posted March 15, 2011 Posted March 15, 2011 The engine is a N/A engine from the celica, a 2.2 litre donk. My question is, if this were turbocharged, would this setup make 40,000hp, in other words, a locomotive pulling starlet. Would be it better than a 3sgte even. Quote
yaristurbo Posted March 15, 2011 Posted March 15, 2011 the 3sgte head fits that block, its like a what a 5e is to a 4e.speak to dan on tgtt, YVS built his i think thats a 3s.unsure of the work thats needed for it, its also in a camry.i looked to lol Quote
Russleh Posted March 15, 2011 Posted March 15, 2011 40000 horses is quite a high target i must say lol. 2.2 litle engine will be a squeeze as is the 3sgte which is also very heavy any im sure it turned out expensive Quote
yaristurbo Posted March 16, 2011 Posted March 16, 2011 also i must add the weight of those engines is alot, it all brings down the power to weight, but my mate chris's mr2 wat 635bhp which makes power to weight very high lol Quote
redz11 Posted March 16, 2011 Posted March 16, 2011 all i saw was 40,000hp i wants this!seriously.. its late at night, would be interesting to see it done Quote
TheStarletGT Posted March 16, 2011 Author Posted March 16, 2011 because i was just thinking this >Install the standard 2.2turbo itRun 5 psi boostShouldnt it be alot better kinda than a 2 litre. Its kinda like stroked to say the least. Quote
Dean @RW-Developments Posted March 16, 2011 Posted March 16, 2011 5psi lol if i was gonna go to all that hassle fitting the 2.2 id be running a gt40 turbo at 2 bar Quote
TheStarletGT Posted March 16, 2011 Author Posted March 16, 2011 If the n/a rods are strong, maybe 10psi would be good for a street setup.I would not go to the extent of making forged rods to suit a 2.2 to boost it to 20psi, because the pistons would be high comp. Too expensive route. I was just thinking of a quick street 2.2 turbo. Quote
Guest Enzo Posted March 16, 2011 Posted March 16, 2011 is this the block people use to stroke a 3s?also its a really really heavy engine for an ep chassis, have you thought about any of the v6s1mz-fe3VZ-FEor my fav the 2gr-fethe 1mz is all alloy and a good 20-30 kilos lighter than your heavy 5sthe 2gr-fe is uber light lighter than the cast iron 4age block + ancilarys.just food for thought but the 1mz and 3vz can be found in donor camrys for much cheapnesss(400+) Quote
starlet666 Posted March 16, 2011 Posted March 16, 2011 is this the block people use to stroke a 3s?also its a really really heavy engine for an ep chassis, have you thought about any of the v6s1mz-fe3VZ-FEor my fav the 2gr-fethe 1mz is all alloy and a good 20-30 kilos lighter than your heavy 5sthe 2gr-fe is uber light lighter than the cast iron 4age block + ancilarys.just food for thought but the 1mz and 3vz can be found in donor camrys for much cheapnesss(400+)5s being a block to stroke a 3s no, they use a 3s block and get a new crank and rods made up, a 3sgte head does fit on the 5sfe block with a little work, and can handle about 15-18psi before u have too much drama (i did it to my old celica)v6 will not physically fit in a starlet engine bay real easy, its bad enough to jam it in a celica, and i almost did it, but wasnt worth the hasslethis guy posting these threads should just stop, he is a troll and a waste of time... all of the aussies that are on here will know him well from all the australian forums he is banned from cause he is a retard Quote
Ricky@Race-Tech Posted March 16, 2011 Posted March 16, 2011 starting to like you dean!!!!! I run a GT40 at 2.2 bar.... Does that mean you do like me Gaz. Quote
Sparky Posted March 16, 2011 Posted March 16, 2011 Why would you go through all that hassle just for a "street setup"Whats wrong with a hybrid or td04 4e for a street setup???? Quote
starlet666 Posted March 16, 2011 Posted March 16, 2011 cause he is an internet troll and a dipshit.... he is the most annoying person to have on a forum due to his stupidity... Quote
Mo3 Posted March 16, 2011 Posted March 16, 2011 ^^^^^^^^^^^^^^^^^^^^cause he is an internet troll and a dipshit.... he is the most annoying person to have on a forum due to his stupidity... Quote
yaristurbo Posted March 16, 2011 Posted March 16, 2011 Lol to these troll posts, keyboard warrior Quote
Mo3 Posted March 16, 2011 Posted March 16, 2011 actually trying fiting a 6.0ltr v8 into your gt :S and add a t3 onto that if u want dodger cordial. Quote
GAZ@A&G_TUNING Posted March 16, 2011 Posted March 16, 2011 NA rick never liked you!!!! that thingy turned up yesterday, hush hush!!! , i'll buzz ya later bout few other thing's dude Quote
Dan507 Posted March 16, 2011 Posted March 16, 2011 Seriously? all that hassle for 5psi ??Thats so much fail my face hurts. That would be like having Megan Fox as your girlfriend and then turning gay. *shakes head* Quote
