Akyakapotter's Forged Glanza V
Looking good. Will be good to thrash round the track :)
I fitted a braided cluch line on the 70. It does make a difference
I didnt think it would I was wrong I cant wait to thrash it round track just need to fit the brake kit and the rainsport 3s if the rain ever stops long enough to do it :D
  • Replies 1.8k
started fitting my braided brake lines ran into a problem with the rear one that goes from the caliper. the fitting is to small so it can pass through the bracket meaning the clips that hold it in place is useless. going to use a washer to stop this :( one brake line fitting is being a bugger went and got a brake pipe spanner and some wd-40 will crack on when its not raining also just won a oil sanwich plate on the bay for £6.75 bargin :D
Edited by akyakapotter
Today has been a good day sort of (GF ended things owell) managed to get the old discs off glad really the stock one were almost past it. new ones on bleeding of the brakes done first time I've done it was easy so my full td fast road brake kit is fitted. My bargin sanwhich plate turned up well worth the £3.75 all because of a few marks and my gear box oil turned up all in all a good day :)
How hard was it to fit the sandwhich plate? As i read you need to trim the PAS down or somthing? This is my next thing on my list..
Was so easy mate 2 bots and loosen the tension bolt to whip the power steering pump off 2 more to take the bracket off and then attack with the grinder for a few mins :)
  • akyakapotter changed the title to Akyakapotter's Forged Glanza V
