nazzurro19 Posted August 7, 2011 Posted August 7, 2011 i was just wondering how so many of you guys make ya cars pop n bang ?i have the mani downpipe and the whole exhaust wrapped and it only occasionally pops if... i drive along in second at 20mph and just let the car slowly roll to a stop then before its about to stall it gurggles a littleso what techniques/things do you do to make noise Quote
GT Phayer Posted August 7, 2011 Posted August 7, 2011 i think its defo fueling but i thought most of it was over fueling on over run Quote
Idrees Posted August 7, 2011 Posted August 7, 2011 Play with the accelerator, tap it a tiny bit Quote
Socks Posted August 7, 2011 Posted August 7, 2011 tickle the throttle pedal on overun... only tickle tho! Quote
Socks Posted August 7, 2011 Posted August 7, 2011 drive let it rev up to like 5-6k then let off and leave it in gear...then just tickle the throttle pedal Quote
raffa_mk Posted August 7, 2011 Posted August 7, 2011 I get that when on the motorway or when the exhaust temp is high Quote
ryan lang Posted August 7, 2011 Posted August 7, 2011 or just run it rich, but thats no good lol. so yer as others stated get up to a high rpm and just take your foot off the throttle and tap it while your revs drop Quote
Josh@TunerLifestyle Posted August 7, 2011 Posted August 7, 2011 id like to do this also! dose pop a tiny bit when i tickle the accelerator but not as much as id like, I've got the decat rite down the whole exhaust wrapped , I've got a roadrunner mani, is it easy to wrap? Quote
_shaun_ Posted August 7, 2011 Posted August 7, 2011 mines not heat wraped but when i hit full boost and change gear kicks a flame out the back waiting for a new laptop battery n gonna have a go at setting up ma launch control for some proper fun and flames tho Quote
neilsmith Posted August 7, 2011 Posted August 7, 2011 Lots of boost and to much fuel makes it pop, my car used to shoot huge flames out the back just by giving it a rev then i found out it was overfueling so i got the fueling sorted out and it doesnt pop now Quote
Steve GT Posted August 7, 2011 Posted August 7, 2011 i know a few people who have used thesehttp://www.ebay.co.uk/itm/EXHAUST-FLAMER-K...=item5ae180271a Quote
GlanzaJim Posted August 7, 2011 Posted August 7, 2011 I think most of them flick the keyhaha mine started doing without the key when it was on3 cylindersif u wana pop do your fueling Quote
craigant Posted August 7, 2011 Posted August 7, 2011 give it half a second between changes when your giving it some, not the best for speed but gives a nice bang and flame for me. Quote
TheStarletGT Posted August 8, 2011 Posted August 8, 2011 Antilag is shet, if you want some real flames, do what i did to get a real flames, in which i cant disclose. I could produce the above pic even when driving.Would make all those ricers beg for mercy. Already did. Quote
Mo3 Posted August 8, 2011 Posted August 8, 2011 Antilag is shet, if you want some real flames, do what i did to get a real flames, in which i cant disclose. I could produce the above pic even when driving.Would make all those ricers beg for mercy. Already did.your just a legend man Quote
Steve GT Posted August 8, 2011 Posted August 8, 2011 Ya but are they any good thowell they certainly do there job mate. I've seen them in action they shoot huge flames out. all it is basically is a spark plug in the exhaust and a little power pack which provides the power. when fumes come out the exhaust it hits the spark plug and hey presto much flamage Quote
Glanza_cl Posted August 8, 2011 Posted August 8, 2011 With the small displacement engine and short downpipe Ep's are never going to pop and bang like mad as the fuel doesn't hit the exhaust in the same way.The pops and bangs is purely excess fuel igniting in your exhaust system (not necessarily good long term). Flames are the same but with allot more fuel being burnt in the system. You can achieve it but need a standalone or piggy back thats fully mappable.... on the map it would need to run rich top end of the rev map but also when you come off throttle the map can be made so the injectors still add a tiny bit, this will end up in the exhaust and when hot enough will ignite and cause the 'pops/bangs'.MR2's are known for popping and banging like crazy! my rev4 with a straight through buddyclub was just silly . Can be done with an EP but needs a good ecu and lots of fuel. Quote
Georgie Posted August 8, 2011 Posted August 8, 2011 With the small displacement engine and short downpipe Ep's are never going to pop and bang like mad as the fuel doesn't hit the exhaust in the same way.The pops and bangs is purely excess fuel igniting in your exhaust system (not necessarily good long term). Flames are the same but with allot more fuel being burnt in the system. You can achieve it but need a standalone or piggy back thats fully mappable.... on the map it would need to run rich top end of the rev map but also when you come off throttle the map can be made so the injectors still add a tiny bit, this will end up in the exhaust and when hot enough will ignite and cause the 'pops/bangs'.MR2's are known for popping and banging like crazy! my rev4 with a straight through buddyclub was just silly . Can be done with an EP but needs a good ecu and lots of fuel.lol the other halfs mr2 sounds like a gunshot, its mental! Quote
Amjad Posted August 8, 2011 Posted August 8, 2011 Play with the accelerator, tap it a tiny bitdrive let it rev up to like 5-6k then let off and leave it in gear...then just tickle the throttle pedal ^This, but mine bangs from only 4k, don't take it higher tbhI haven't spotted flames though (0.95bar CT9). I want them lol Quote
nazzurro19 Posted August 8, 2011 Author Posted August 8, 2011 haha i was hoping id be able to do it staticly but ill give it a try next time i go down an A road lol Quote
