Johnboy GT Posted November 6, 2014 Posted November 6, 2014 Let's hear an update then Mark? John Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 I have an update soon this weekend or possibly even sooner!I have been busy And also been neglecting the owners club unless Gray91 tells me something is worth buying hahaba Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 (edited) Hi guys, I have been far too busy and have put this off for far too long As you know i have down sized to a VF22 cermaic ball bearing turbo. Over the past few months i set about impoving breathing of the car. I ditched the nasty hot side intercooler pipe that kept blowing off, i made a "quick fix" for over a year ago it pulls much much better on full boost i also removed 2 silicone joiners from the cold side pipe. after the test drive the exhaust was sounding better, felt better to drive and did not hit the chassis at all I also got rid of the japspeed front pipe as its ONLY 2 3/8! so i set about making a 3" system and ended up using an evo rear box and a down turned "chode tip" hahaha the 2.5" flange has a homemade cone reducer to bring it up to 3" So i have a look around ad found a spare downpipe flange and bout more 3" pipe, stainless bar for hangers, 2x 3" 90 degree bends and a 3"X6" flexi I also got a new bucket seat and harness I wil show you guys later the harness bar set up. and i made the seat rail myself too The battery is also relocated to the boot, i made the battery tray out of 2mm stainless steel and it lined with single sided foam. After fitting an oil cooler and oil filter relocation kit i moved the window washer bottle to the boot and make a 6"x6"x6" 2mm alloy tank also. i ran the lines behind the roof lining and you cant see them at all (with a one way valve) Edited April 23, 2015 by mark1991 Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 If any of the shire guys need odd welding jobs give me a shout, i will try to arrange meets again and be on here more often Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 i was fixing it first, couldnt get on to photobucket. should be ok now tho Quote
Jamie_VF22 Posted April 23, 2015 Posted April 23, 2015 Looking good mark when you having it mapped again intrested seeing what my old VF22 will do All the best pal Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 Cheers I have a new inlet to make then mapping in the summeri think Quote
Johnboy GT Posted April 23, 2015 Posted April 23, 2015 Aye about time bud! Good progress, had been seeing updates on fb! I was thinking about getting you to do a job for me but I will.wait till mine is on the road for thatJohn Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 I will upload pictures of my homemade short shifter very soonCheers John, just let me know Quote
5e colin Posted April 23, 2015 Posted April 23, 2015 how long have you been tigging mark looks good to me keep up the d.i.y. stuff i like Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 I have been welding for 6 years but at the start i was just MIG welding, i have been getting more into stick and TIG welding stainless and exotic aloys at my current workplace. cheers Colin Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 here is my short shift i made due to me being fussy and none of the ones that are mass produced where what i was really after,I wanted the shift to sit higher up but still be a shorter throw, so extenting the stick was a no and i wanted less of a reach to the stickand i end up with this \/\/\/ a idea of how much i added into a standard shifter. I have it towards the drivers seat a fair amount and made spacers to clear the floor and also rasie the shifter up am extra 25mm, the body of the shift had to be cut and tweeked to let the cable sit so low but in the end it really was a great result over the TRD item Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 (edited) I also made a few changes to the dash, I now have oil pres, oil temp, fuel pres and water temp I removed one of the air vents to put my horn button and windscreen washer button there (i dont have those switches any more, now just push buttons) so i could remove the horn stuff from the wheel and blank it with carbon As before i had the gizzmo in the hi/lo boost button slot, you will notice that i have moved the hazzard and rear window heater buttons around Edited April 23, 2015 by mark1991 Quote
Calum122 Posted April 23, 2015 Posted April 23, 2015 Removed the horn lol. That's great. Very sick build. Quote
Cammy R Posted April 23, 2015 Posted April 23, 2015 If any of the shire guys need odd welding jobs give me a shout, i will try to arrange meets again and be on here more often meets sound good Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 They do indeed mate, I will sort one out soon Quote
mikey4410 Posted April 23, 2015 Posted April 23, 2015 just had a good look through this.wicked build dude.very nice.love how u have done quite a bit of the fabricating ureself. Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 Cheers Mikey, I will have missed out more stuff so I will upload more tonight Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 This is my current set up as a harness bar, I have a homemade bracket bolted to the ear seatbelt mounts and an extra bar welded into the cage Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 and this is how the DIY shift sits when driving. it sits much closer and does feel alot better only downside is the gear gaiter does not fit now... but i plan on making one Quote
mark1991 Posted April 23, 2015 Author Posted April 23, 2015 (edited) TD05 18G VS IHI VF22 This is the making is the alloy washer tank that is relocated to the boot there is a baffle inside altho its there for no real reason at all I also had a side exit tail end of last year too, was very loud and loved a flameeven worse when it had a sulk and ran very rich... Edited April 23, 2015 by mark1991 Quote
mark1991 Posted January 19, 2016 Author Posted January 19, 2016 UPDATE after buying a house i have started work! i have since made my own ram horn manifold, 3" bumper exit exhaust, 3" pie cut turbo inlet pipeshort route intercooler pipe work Quote
diller Posted January 19, 2016 Posted January 19, 2016 Back from the depths Skillz on the manifold Mark Quote
