Glanza Mac Posted February 12, 2012 Author Posted February 12, 2012 (edited) ohh its been a long wait, should hear her purr in the next week or two , thanks dude Edited February 12, 2012 by Glanza Mac Quote
Glanza Mac Posted February 15, 2012 Author Posted February 15, 2012 I love my postlady as she brought this today Sard FPRAlso the Gauge too Not much more i have to buy now untill im all sorted, just need to find a 90 Degrees silicone hose to join my TD04 and intercooler pipe together, few vacuum pipes, coolant and some power steering fluid Quote
Glanza Mac Posted February 16, 2012 Author Posted February 16, 2012 (edited) Well ive been busy today trying to get things sorted Got the engine attatch to the crane, even tho it took me an hour to set it all up (i.e add oil etc because its pretty much had it) Attatched the flywheel, torqued it up to manufacturers spec and clutch assembly also Starlet Book (clutch torque settings etc) Aligned the clutch Cleaned my old rocker cover up and then started to spray Etch Grey primer Chilli Orange- Gu1 (Corsa Nurburgring VXR) Thought it was too much so went for something different.. Ford Sea Grey + Clear Lacquer Unsure if i like it yet but i will see what it looks like on the engine when its in Fitted my Braided hoses And i bought some Orange rocker cover nuts and some smaller ones just to smarten some things up a bit. Waiting for my fuel rail adapter so i can fit my FPR, Heat wrap + steel ties to wrap my manifold, decat and screamer and 15 orange washers to smarten up the engine bay. Still need to buy a 70mm-50mm reducer 90 degree's white silicone hose for my turbo/intercooler but cant find one in white Edited February 16, 2012 by Glanza Mac Quote
lew777 Posted February 16, 2012 Posted February 16, 2012 rocker cover might look good in the sun Quote
Glanza Mac Posted February 17, 2012 Author Posted February 17, 2012 Been a busy day today.Received my Titanium heat wrap today through the post plus some metal tie wraps.Manifold WrappedEngine going inEngine InHmm this may take a while to put back togetherFuel rail, wastegate vaccum hose in place just need to order another etcPower steering res, pump etc connectedi do have this problem tho, this location pin on the gearbox needs to be cut and drilled out into a hole as my engine has the same location pin in the same place... ball ache as ill have to cut, drill etc but will get it done hopefully in the week and get the gearbox fitted Quote
Glanza Mac Posted February 18, 2012 Author Posted February 18, 2012 Today i changed my fuel return pipe for some longer clear piping to link up to my FPRTried to make it tidyFuel rail adapterFPRConnectedRemoved everything to swap the rocker covers overRocker cover off and its all shiney and cleanCam lobes (very shiney and dont look standard)New rocker cover on (dislike it) and orange rocker nutsorange nut on the other side of the dizzyAll together Quote
The Prodigy Posted February 19, 2012 Posted February 19, 2012 Be sure to put up a video once it's running again Quote
RobSR Posted February 20, 2012 Posted February 20, 2012 Just make sure that pipe youve used can stand up to fuel + its pressure! also move your vac line from the top of the wastegate to the side port Quote
Glanza Mac Posted February 20, 2012 Author Posted February 20, 2012 the fuel line is only a temp fit but it is proper fuel hose that i use on my 100cc kart , yeahh im new to the ex wastegate haha, need to read up on a few things tbh but i will get there Quote
Socks Posted February 20, 2012 Posted February 20, 2012 Looking forward to seeing this in summer hopefully! Your not far from me either! Quote
Glanza Mac Posted February 20, 2012 Author Posted February 20, 2012 nope im going to all the major shows for sure but im hoping to do a few of the starlets meets near by i.e the cleethorpes ones up to nottingham etc Quote
Glanza Mac Posted February 23, 2012 Author Posted February 23, 2012 Tegiwa orange anodized washers and countersunk bolts A few fittedmore updates this weekend when hopefully the gearbox will be going in Quote
Glanza Mac Posted March 5, 2012 Author Posted March 5, 2012 Well ive been busy over the weekend, gearbox in, oils in, pretty much everything connectedGearbox in, just misplaced a gearbox mount.. ooopsRadiator in placeMy Mums Beetle helping the glanza out (didnt work as my battery dead and mums not very good either)Fpr.. bit high? (60psi)Pioneer Dvd i bought about 5 months ago that ive never tried out untill nowPicture of speedo to prove when the new engine went in etc thats all for now. Quote
Glanza Mac Posted March 28, 2012 Author Posted March 28, 2012 Engines in etc, still no spark and ive done many tests and checks so im lead to beleive its only the coil left to blame, shall be ordering one and fingers crossed ..Bought a few things recently..New carbon blitz gauge + pod Compared to old oneSome Stickers i bought at fast showAnd my favorite one is this one..... i shall be moving my tax disc Quote
eazalee Posted March 29, 2012 Posted March 29, 2012 nice read getting as much info as i can so if i get my own soon ill have a better idea Quote
Glanza Mac Posted March 29, 2012 Author Posted March 29, 2012 thanks dude yeahh glanza's are the way forward Quote
Glanza Mac Posted April 3, 2012 Author Posted April 3, 2012 Been very busy the weekend just gone, a friend came round to swap a few components over to see if it was them at fault on my glanza.Changed plugs.. no sparkChanged leads.. no sparkDid a resistance check on the ignition coil as i got no spark from the king lead.. no sparkChecked dizzy and rotor arm.. no sparkSwapped ignitor.. no sparkEven swapped the ecu.. no sparkBut all of the above worked on my friends glanza so my components were not at fault.So i carried out a diagnostic fault code check and i got the follow..Fault code12. RPM Signal 14. Ignition Signal22. CTSAll underlying faults with the ignition system which was obvious.So the last resort was to do a simple thing and replace the orange anodised washer and flush allen bolt that i had bolted the ignitor with.. could maybe stop the ignitor from earthing...Turned the key and the Glanza came to life.. IT LIVES!so the glanza runs but came to another problem as it idles at 1750 to 2000 and pulsates which is abit annoying but im hoping it because at the time the intercooler pipes were not fitted so fingers crossed thats the problem but besides that it sounds pretty sweet .. Happy Days ! Quote
akyakapotter Posted April 3, 2012 Posted April 3, 2012 your FPR is in the same place as mine held in by cable ties. Quote
Glanza Mac Posted April 10, 2012 Author Posted April 10, 2012 Recently bought a Carbon Fibre ducktail spoiler and Carbon Fibre rear Oem splitter from Browner so just waiting for that to be delivered... cant wait Quote
Liam_D Posted April 10, 2012 Posted April 10, 2012 Awesome!! Pretty jealous about the rear splitter. I miss my old one a lot shoulda never sold it. Quote
