lew777 Posted October 24, 2011 Posted October 24, 2011 where is the best place to weld the sensor in?thanks in advance Quote
funny onion Posted October 24, 2011 Posted October 24, 2011 In the downpipe, where the normal lambda is. Basically after the turbo, keeping as few gaskets between the turbo and sensor as possible Quote
federalman Posted October 24, 2011 Posted October 24, 2011 I got rid of the lambda all together didnt have a problem on the ct9 with fuelling but now ive gone td04 im upping the pressure a bit Quote
lew777 Posted October 25, 2011 Author Posted October 25, 2011 So just stick it in the lambda hole then Quote
jackjohno Posted October 25, 2011 Posted October 25, 2011 On the second hole in de downpipe :If u read the instructions on a turbo charged car it should be 36 " away from turbo i welded mine in at the bottom of the bulk head (fire wall) Quote
Simon Posted October 25, 2011 Posted October 25, 2011 agree with the above fitted mine just after the gearbox mount easy to route the wiring up the back of the bulkhead then and into the cabin Quote
Socks Posted October 25, 2011 Posted October 25, 2011 on kidv's we took the stock lambda out cus they dont do shit anyways saves you fucking about welding! Quote
MARK@CMBAUTOS Posted October 25, 2011 Posted October 25, 2011 agree with the above fitted mine just after the gearbox mount easy to route the wiring up the back of the bulkhead then and into the cabinx2 Quote
Bean Posted October 25, 2011 Posted October 25, 2011 After gearboxthis is where they should go not in the down pipe as it decreases the life of them. in the manual it says how far they should be from the turbo. Quote
Bean Posted October 25, 2011 Posted October 25, 2011 that sounds familiar. i know Dave b always said to fit them behind the gearbox. alsso you want the tip of the sensor (the part inside the exhaust) pointing down at a bit of an angle and the end out of the exhaust pointing up. Quote
nastyrash 2003 Posted October 25, 2011 Posted October 25, 2011 just watch out for bangin it thy very delacat. thats the problem with fitting thm under the car if it takes a nock i always fit on down pipe if poss, warms up faster and does not tend to soot up .chris Quote
5T4R7ET N/A Posted October 25, 2011 Posted October 25, 2011 on kidv's we took the stock lambda out cus they dont do shit anyways saves you fucking about welding!is that true?thought lambda sensor was used for fueling. Quote
nastyrash 2003 Posted October 25, 2011 Posted October 25, 2011 ^^ i would never do this. its so easy to fit a wide band. chris. Quote
Jamie1st Posted October 25, 2011 Posted October 25, 2011 36" from turbo, heres a pic of mine:Jamiw Quote
_shaun_ Posted October 25, 2011 Posted October 25, 2011 i had the stock lamda removed but when we went to set up the emu it had to get pluged back in as it was causing all sorts of problems Quote
Asad Posted October 25, 2011 Posted October 25, 2011 thats roughly where the N/A lambda sensor is just that it points at the 10-11 o`clock position Quote
lew777 Posted October 26, 2011 Author Posted October 26, 2011 @jamie how did you get the cable into the cabin from there? Quote
Jeroen W. Posted October 26, 2011 Posted October 26, 2011 It works perfect so i haven't had any problem..I know that it's in the instruction.. but why? what is the differents? Quote
Asad Posted October 26, 2011 Posted October 26, 2011 Reduces the life of the sensor and at £50-70? A pop i wouldnt want to comprimize it Its also got something to with moisture or w/e falling on to sensor at the 90 degree angle and damaging it/reducing its life so thats why they say place them in the 12 o'clock vertical position at a certain length away Quote
Jamie1st Posted October 26, 2011 Posted October 26, 2011 @jamie how did you get the cable into the cabin from there?From there you can run it straight up the bulkhead/baqck of engine bay then through a grommet to your dash area. Just remember to cable tie all the way up to reduce the risk of the cable coming loose and hitting the floor.Jamie Quote
federalman Posted October 26, 2011 Posted October 26, 2011 AEM say 36 inches from the turbo is the best place but I couldnt be arsed to drill a hole and weld the boss into either my td04 decat or HKS system so lambda boss it was Quote
funny onion Posted October 26, 2011 Posted October 26, 2011 36 inches is only a guideline- they say that because the closer you put it to the engine, the more turbulent the gases are and hence the reading from the sensor may be affected. But you do get a more true reading of the exhaust gas mixture the closer you put it to the engine. I work with these type of sensors at uni, and they can be sensitive to knocks and bumps so bear that in mind when you decide where to put it Quote
