Is there any way of telling if a car had one factory fitted other than getting under the car (like on the Levins that have an extra letter or number on the VIN?)
Also if you jack it up and spin one wheel, the opposite wheel should go in the opposite direction even when you make your misses hold onto it.
Are the driveshafts green on all of them (Including non LSD)?
And do all Glanza's have a sticker on the inside of the (If memory serves me correctly) Passenger door stating that because its an LSD box you should use 'blah blah' oil?
Just out of interest :p
No all of them have that
its tyre pressures
as they are different if you have a full size spare (means lsd)
