Low is 0.45ish and high 0.65ish I think
Don't any flow modifications help boost get a bit higher?
Edited by Amjad
  • 3 weeks later...
If your boost gauge is accurate and reading 0.9 bar then you should hit fuel cut, unless you have a fcd or even better a plug and play ecu.
x2, would defo be hitting fuel cut at .9.... have a look see for a fcd or plug and play as said above, ecu is located behind the center console at the bottom
Well it's a new boost guage and got a garage to fit it as I wouldn't have a clue on how to do it haha even though it came with instructions :/ haha
And ok then mate, I'll have a look tomorrow, see if I have an upgraded ecu :)
This shall be fun..
Hey,
Sorry if im a pain :p
But, I'm now boosting NEARLY 1.1 bar!?
With just exhaust system, decat and front mount air filter?..
Is this right?
And sometimes, I do get fuel cut in 3rd but that's only happened like 2-3 times..
It's very possible with the mods u have fm de-cat etc it's all creating either more air and a better flow through your exhaust
