james@cjperformance Posted October 2, 2012 Share Posted October 2, 2012 Hi guys and girlsWe are now able to offer a forged piston and rod combo, we can offer a 4e or 5e package and pistons sizes will be available in 74, 74.5 and 75mmOur very own custom made rods specs are below- Precision forged 4340 EN24 aircraft chrome moly quality steel- 2-Piece forging for increased strength- Multi-stage heat treated processes- Packaged in weight tolerance per set: end to end +/- 1 gram- All forging are X-rayed, sonic tested and magnafluxed- Shot peened to stress relieve the metal- Precision alignment sleeves positively locate the rod cap, maintaining big end bore size and eliminating cap walkwe have been in touch with cp pistons and they have offered us a fantastic deal on any size pistons,CP Pistons are available standard or oversized. CP pistons are compatible with oversize valves and higher lift cams. Specific X designated part numbers incorporate an X-style forging for additional strength, durability and weight reduction. Along with full radius dome designs, high performance rings and lightweight pins, CP Pistons represent the highest quality and are engineered for maximum power. Pistons can be ordered with skirt coating if desired.STANDARD FEATURES INCLUDE:§ Deep valve relief depth accommodates high lift camshaft§ Made for +1mm valve sizes§ Custom skirt cam and barrel design§ Accumulator grooves§ High strength aluminum forgings§ High performance rings§ Fully CNC machined and balanced to +/- 1 gram§ Wrist pins included at no additional cost§ Double pin oilers, force fed oil ring§ Pick lock grooves for easy lock removal§ Pin fitting includedif we run a group buy on them and get 5 confirmed people we can get these out at an amazing price of £565 deliveredany questions let me knowcheers james1.2.kyle- 5e3.ollie454-4E with 74mm pistons4.5.dobbs-4E with 74.5mm pistons Link to post Share on other sites
ollie454 Posted October 2, 2012 Share Posted October 2, 2012 Will be very interested in these dude as you already know Link to post Share on other sites
Starbo Moorley Posted October 2, 2012 Share Posted October 2, 2012 Are the rods proven ? Im very interested, got me a 4e sat inbits here and i need some shiny pistons and rods to put in it ! Link to post Share on other sites
akyakapotter Posted October 2, 2012 Share Posted October 2, 2012 Are the rods proven ? Im very interested, got me a 4e sat inbits here and i need some shiny pistons and rods to put in it !I was thinking this that to have they been tested ? Link to post Share on other sites
james@cjperformance Posted October 3, 2012 Author Share Posted October 3, 2012 One xof my customers has been usimg them. Been running 1.6 bar on a vf30 fpr the past 8.5 months. Standard rev limit.The only difference is he is using wossner pistons not cp pistons will post full spec list tommorow We were going to release them earlier in the year after the build was finiahed but didnt feel confortable with it Link to post Share on other sites
Rossi_Glanza Posted October 3, 2012 Share Posted October 3, 2012 Does the block need to be knotched to accomadate the rods?Thanks Ross Link to post Share on other sites
lukEp Posted October 3, 2012 Share Posted October 3, 2012 (edited) I'm in 5e @ 74.5mm pistonsDoes this kit include a full ring set? Edited October 3, 2012 by lukEp Link to post Share on other sites
james@cjperformance Posted October 3, 2012 Author Share Posted October 3, 2012 @ ross yeah block needs to be knotched dude. They are the same specs as scat rods @ luke yes they come with a full ring set pins and locks Link to post Share on other sites
Broony Posted October 3, 2012 Share Posted October 3, 2012 Do the rods come with testing data and spec sheets of proven tolerances they can withstand?? Link to post Share on other sites
james@cjperformance Posted October 3, 2012 Author Share Posted October 3, 2012 Im inwhich ones dude, 4e or 5e and what piston size would you be wanting Link to post Share on other sites
james@cjperformance Posted October 3, 2012 Author Share Posted October 3, 2012 Do the rods come with testing data and spec sheets of proven tolerances they can withstand??They will come with a spec sheet with all the size data to ensure tolerances are met when building.as for testing, the company making these rods specifically for us have been in business for 20+ years the set of rods that were produced would have been tested by the manufacturer I can get them to include what tests were carried out prior to being produced. I will email them now to get all the relavant data Link to post Share on other sites
Broony Posted October 3, 2012 Share Posted October 3, 2012 They will come with a spec sheet with all the size data to ensure tolerances are met when building.as for testing, the company making these rods specifically for us have been in business for 20+ years the set of rods that were produced would have been tested by the manufacturer I can get them to include what tests were carried out prior to being produced. I will email them now to get all the relavant data Im interested, may have a lil project over the winter Link to post Share on other sites
lukEp Posted October 3, 2012 Share Posted October 3, 2012 (edited) What about compression ratio James are they machined to standard or are they lower? Edited October 3, 2012 by lukEp Link to post Share on other sites
james@cjperformance Posted October 3, 2012 Author Share Posted October 3, 2012 ^ machined to standard dude Link to post Share on other sites
turbo Grant Posted October 3, 2012 Share Posted October 3, 2012 The paseo is wanting this kit in the new year. Green one has priority Link to post Share on other sites
Chesh Posted October 3, 2012 Share Posted October 3, 2012 I'm wanting 74mm for 5E thanks Link to post Share on other sites
james@cjperformance Posted October 3, 2012 Author Share Posted October 3, 2012 added you to the list dude Link to post Share on other sites
james@cjperformance Posted October 4, 2012 Author Share Posted October 4, 2012 bump Link to post Share on other sites
dobbs Posted October 5, 2012 Share Posted October 5, 2012 Count me in please 74.5 Sorry for 4efte Link to post Share on other sites
james@cjperformance Posted October 5, 2012 Author Share Posted October 5, 2012 added you guys to the list. the pistons will take around 2 weeks to come from cp and the rods around 4l3 as they are all made to order if you guys on the list could drop me a pm to let me know how your fixed for payment i can sort a payment deadline out for this. im wanting them for my build so i van get my car finished too Link to post Share on other sites
james@cjperformance Posted October 5, 2012 Author Share Posted October 5, 2012 bump Link to post Share on other sites
lukEp Posted October 5, 2012 Share Posted October 5, 2012 Rob19 is Chesh mate and I might have to drop out of this already! Sorry ill know more in a few days, I do genuinely want these ESP at this price but some thing come up. Link to post Share on other sites
mark-tozer Posted October 7, 2012 Share Posted October 7, 2012 how long will this offer be on please and after the offer has finished what will be the normal price and availabilities thanks Link to post Share on other sites
Tara Posted October 7, 2012 Share Posted October 7, 2012 Price after the group buy be around £670 delivered, this price will run until the 5 slots have been filled and payments received Link to post Share on other sites
