Hello everyone
I have been told a td04 will spool very very quick on a 5e but what would a td05 on a 5e will spool like and what power would it put out runing 1.4 bar
Thanks
Real men use Garrett :p
Its hard to judge what spool time will be like as it varies too much, things like compression ratio, cams, piston size, air temp, what ecu you run, the tune etc.
Id say at a guess 1 bar @ 3000rpm.
  • 2 weeks later...
  • 3 years later...
