Neil69 Posted November 7, 2012 Share Posted November 7, 2012 (edited) Just a few piccys to get startedEarlier pics still on old phone i will get them up soon.Started out as 46k mile granny spec 1e in off white as many years of not being cleaned had took hold.Drove it like that for 6 months then started the strip and modify!!!Half painted at the minute in the brightest white I could find with gloss black roof. Edited November 7, 2012 by Neil69 Quote Link to post Share on other sites
TrisK Posted November 7, 2012 Share Posted November 7, 2012 have a look at Taggys thread. he did exactly thisbe interesting to see what youve done the same/different Quote Link to post Share on other sites
Neil69 Posted November 7, 2012 Author Share Posted November 7, 2012 (edited) On 11/7/2012 at 11:46 AM, TrisK said: have a look at Taggys thread. he did exactly thisbe interesting to see what youve done the same/differentTo be honest his videos have been quite helpful. I have put discs on the rear which I m not sure if he did and will be running a standard tank not a fuel cell. Other than that I think it is very similar, oh and I cant afford his front brake upgrade either. lol Edited November 7, 2012 by Neil69 Quote Link to post Share on other sites
pick1 Posted November 7, 2012 Share Posted November 7, 2012 Looks awsome nice colour Quote Link to post Share on other sites
Mike@TD.co.uk Posted November 7, 2012 Share Posted November 7, 2012 Coming along niceley Neil! CheersMike JonesTuning Developments Ltd Quote Link to post Share on other sites
Taggy Posted November 7, 2012 Share Posted November 7, 2012 Hey Neil, love the work you have done so far, I am particularly interested in how you have wired in your front brake servo. Since putting mine in my brakes are no where near as sharp as they used to be on the EP82 with the same brake setup. I Am just looking at the routing of your brake lines to see if i have some routed them wrong. will have to compare them.Are you going to be using your stock fuel tank from the Ep70 for some how making the ep82 one fit onto the ep70. Only asking as the ep70 fuel tank isnt suitable for a turbo charged car which is why i put in the fuel cell, its got no swirl pott or baffle in it so if you bank hard around a corner your pump is going to suck up lots of air and run lean. Quote Link to post Share on other sites
Neil69 Posted November 7, 2012 Author Share Posted November 7, 2012 On 11/7/2012 at 12:59 PM, Taggy said: Hey Neil, love the work you have done so far, I am particularly interested in how you have wired in your front brake servo. Since putting mine in my brakes are no where near as sharp as they used to be on the EP82 with the same brake setup. I Am just looking at the routing of your brake lines to see if i have some routed them wrong. will have to compare them.Are you going to be using your stock fuel tank from the Ep70 for some how making the ep82 one fit onto the ep70. Only asking as the ep70 fuel tank isnt suitable for a turbo charged car which is why i put in the fuel cell, its got no swirl pott or baffle in it so if you bank hard around a corner your pump is going to suck up lots of air and run lean.I just copied the routing of the EP70 brake pipe layout. Just had to change one pipe from the 82 between the master and 4 way block on the bulkhead as the ep70 was too short. I have ordered a boltt in unit from usa which has a baffle/collector built in the bottom of it. It needs 6 inch clearance and the tank has 7 inches from the old pickup mounting. The unit comes with a 255 lph walbro pump mounted inside and a return and vent. Hope it works!! Quote Link to post Share on other sites
Neil69 Posted November 7, 2012 Author Share Posted November 7, 2012 Just thought I would throw a random picture in of my last project I did.The blue MK5 Cortina is my one and the Granada is a friends that we rebuilt last year together. Quote Link to post Share on other sites
rumaray Posted November 7, 2012 Share Posted November 7, 2012 nice project hommie keep us postin with the beast............ hey taggy need you for some questions Quote Link to post Share on other sites
Neil69 Posted November 7, 2012 Author Share Posted November 7, 2012 Right found the early pics of the car. just before I took it all apartStarted to take it apartThe worst rust on the body was at the bottom of both a pillars, cut the outer skin off both at the bottom and let new metal in. Nothing major though. Rest of the body was only surface rust really.Oh and here is the doner car!! Quote Link to post Share on other sites
micky boy Posted November 7, 2012 Share Posted November 7, 2012 Now Im likeing this looking good mate Quote Link to post Share on other sites
Neil69 Posted November 8, 2012 Author Share Posted November 8, 2012 Piccy of the engine in the hole Quote Link to post Share on other sites
Starbuck Posted November 8, 2012 Share Posted November 8, 2012 Nom nom Quote Link to post Share on other sites
Stu Posted November 9, 2012 Share Posted November 9, 2012 Looking good Quote Link to post Share on other sites
Taggy Posted November 9, 2012 Share Posted November 9, 2012 bloody hell your not hanging about are you What did you plan to do for the electrics? Quote Link to post Share on other sites
Max9650 Posted November 9, 2012 Share Posted November 9, 2012 one of my neighbours at the flat im moving into next month has one of these in red, hope its a 4efte sleeper, somhow doubt it though lol Quote Link to post Share on other sites
Taggy Posted November 9, 2012 Share Posted November 9, 2012 i checked the plumbing on my brake servo and strangely its the same, hmmm that is odd! Quote Link to post Share on other sites
Neil69 Posted November 9, 2012 Author Share Posted November 9, 2012 (edited) Wiring was removed complete from 82. i have opened the loom. and removed all ancillary wiring so left with engine loom only i hope!! Plan to just solder feeds to original barrel and hide all extra relays away behind dash or in original ep70 fusebox Edited November 9, 2012 by Neil69 Quote Link to post Share on other sites
Taggy Posted November 10, 2012 Share Posted November 10, 2012 That is pretty much what i did, if you get stuck with anything though give me a shout and I can help out Quote Link to post Share on other sites
Neil69 Posted November 10, 2012 Author Share Posted November 10, 2012 Im glad you said that. expect numerous pms.!!! i notice on your brakes you have a valve in the vaccum pipe to the servo. mine is just a short pipe to the inlet manifold maybe that is making a difference. Quote Link to post Share on other sites
rumaray Posted November 12, 2012 Share Posted November 12, 2012 Nice One My Brother Keep Us Updatin Quote Link to post Share on other sites
Taggy Posted November 13, 2012 Share Posted November 13, 2012 Yeah i wil cut it out and see if it helps The ignition wiring isnt as bad as it originally looks, if you check on the back of the ignition plug there are codes stamped onto the female section of the plug, they match up between both cars but are in different pin positions so you will have to do some creative wiring, failing that just copy the colour codes i have soldered together Quote Link to post Share on other sites
turbo Grant Posted November 13, 2012 Share Posted November 13, 2012 You need the valve in servo pipe on a boosted engine. It's a one way valve so it stops you filling the servo with boost and giving you a hard pedaComing along nicelyl Quote Link to post Share on other sites
Taggy Posted November 13, 2012 Share Posted November 13, 2012 ah just as well i left it in then Quote Link to post Share on other sites
Neil69 Posted November 13, 2012 Author Share Posted November 13, 2012 On 11/13/2012 at 9:09 AM, turbo Grant said: You need the valve in servo pipe on a boosted engine. It's a one way valve so it stops you filling the servo with boost and giving you a hard pedaComing along nicelylmy gt turbo or the 70 did not have it!! Maybe i will find one Quote Link to post Share on other sites
