If you go for the anti lift kit sometime in the near future the whiteline anti roll bar will catch the bottom arm! especially if you have coilovers and you are prity low!
But if you go for the TRD anti roll bar it will give you that 2mm clearance!!!! Also whiteline stuff rusts to bits with in a week of been on your car!!! lol
My whiteline rear panard rod still looks like new and is over a year old!
Give it time....IMG_0763.jpg:p
I'd stick with the TRD one the whiteline at 24mm is very thick and hence stiff, I run the 22mm and it's stiff enough.
I've had my RARB on for 3 years, no rust.
Also I run 24mm FARB and ALK and Coils, and I don't have any problems. And my coilovers are lowww
I've had that panhard fitted for probably 5 or 6 years and the car used to be driven daily all year on proper dirty back roads in all weather, the rarb which has been on the car for 3-4 years was bad but not to that extent and the front arb still has the paint on it after a couple of years!
The threads are goosed on the panhard too - no way it would adjust now.
Edited by WallaceGlanza
