trying to explain this best i can haha..
even with OEM suspsension fitted there was a kind of squeking sound coming from the rear and this is inside of the car its not over the top but since fitted new Bc coilovers its got little bit louder its coming from the inside of the car.. no sound out of the car..
its when driving at all times straight lines,cornering.... from 10mph onwards
does not sound bad or something is broken its just annoying as feck haha.....
any ideas??
Inside, erm
Catch on the boot (wrap tape around the pin the hook goes around)
Catches on the rear seats or the hinges
Parcel shelf
If uk spec the rear brake light can squeek.
Just go mad with a bit of silicone grease or get a mate in the back of the car and go for a drive down a "private road" :p
Edited by morgey
Parcel shelf is not in..
it's not like anything is loose or making a rattle sound.. Sounds like the chassis (shell) is straining lol!
Funny enough my brothers does it as well!
So is your total silence inside the cabin minus the exhaust?
Mine creaks and all sorts, always has done since i fitted the braces/ARBs and stuff. Think its just what Starlets do. Everyone ive been in has done the same.
got the same thing.
When i start to drive the car i almost can't hear it but when i have driving it for a while it gets really loud.
Didnt your old white one do it?
Edited by Bryan-4E-FTE
mine is totaly silent try copper greese in the top of the coilover it could be the new rubber
hmmm going to try this me thinks.. as its giving me a head ake haha!
it actually does sound like rubber on metal rubbing well exactly what my mate said when passenger!
on all coils?
well ive greased the rear rubbers up on the coilovers and its helped so MUCH better!
only soaked them in wd40
when i get the time gonna copper grease them
:thumbsup:
Youd be better off with white spray grease, copper grease will work perfectly but the copper is added to resist heat and just makes right mess when its not completely necessary.
If you use it for this it will work fine but will just make it more hassle ud be far neater and less hassle using white spray grease just a little tip.
Will do this then mate
Cheers for that as yes makes sence as its a spray so be easier ..
