iamlegend Posted January 2, 2013 Share Posted January 2, 2013 trying to explain this best i can haha.. even with OEM suspsension fitted there was a kind of squeking sound coming from the rear and this is inside of the car its not over the top but since fitted new Bc coilovers its got little bit louder its coming from the inside of the car.. no sound out of the car.. its when driving at all times straight lines,cornering.... from 10mph onwards does not sound bad or something is broken its just annoying as feck haha.....any ideas?? Quote Link to post Share on other sites
morgey Posted January 2, 2013 Share Posted January 2, 2013 (edited) Inside, ermCatch on the boot (wrap tape around the pin the hook goes around)Catches on the rear seats or the hingesParcel shelfIf uk spec the rear brake light can squeek.Just go mad with a bit of silicone grease or get a mate in the back of the car and go for a drive down a "private road" Edited January 2, 2013 by morgey Quote Link to post Share on other sites
micky boy Posted January 2, 2013 Share Posted January 2, 2013 Not the rubber bits on the parcel shelf rubbing on the boot? Quote Link to post Share on other sites
Liam_D Posted January 2, 2013 Share Posted January 2, 2013 Not the rubber bits on the parcel shelf rubbing on the boot?Mine does this too! Haha Quote Link to post Share on other sites
iamlegend Posted January 2, 2013 Author Share Posted January 2, 2013 Parcel shelf is not in..it's not like anything is loose or making a rattle sound.. Sounds like the chassis (shell) is straining lol!Funny enough my brothers does it as well!So is your total silence inside the cabin minus the exhaust? Quote Link to post Share on other sites
Liam_D Posted January 2, 2013 Share Posted January 2, 2013 Mine creaks and all sorts, always has done since i fitted the braces/ARBs and stuff. Think its just what Starlets do. Everyone ive been in has done the same. Quote Link to post Share on other sites
morgey Posted January 2, 2013 Share Posted January 2, 2013 I've had a squeek only since I've fitted my RARB and my rear light squeeks. I would say its most likely the boot catch or the chassis is just twisting. Had you got a rear strut in it? Quote Link to post Share on other sites
iamlegend Posted January 2, 2013 Author Share Posted January 2, 2013 no rear strut as of yet altho that may help? Quote Link to post Share on other sites
morgey Posted January 2, 2013 Share Posted January 2, 2013 If its the chassis then i'd imagine a strut would help. Quote Link to post Share on other sites
Bryan-4E-FTE Posted January 2, 2013 Share Posted January 2, 2013 (edited) got the same thing.When i start to drive the car i almost can't hear it but when i have driving it for a while it gets really loud.Didnt your old white one do it? Edited January 2, 2013 by Bryan-4E-FTE Quote Link to post Share on other sites
little dave Posted January 2, 2013 Share Posted January 2, 2013 mine is totaly silent try copper greese in the top of the coilover it could be the new rubber Quote Link to post Share on other sites
RicoW Posted January 2, 2013 Share Posted January 2, 2013 pan hard rubbers? Quote Link to post Share on other sites
Amjad Posted January 3, 2013 Share Posted January 3, 2013 I swear someone had a squeaky rear beam a little while ago? Quote Link to post Share on other sites
iamlegend Posted January 4, 2013 Author Share Posted January 4, 2013 mine is totaly silent try copper greese in the top of the coilover it could be the new rubberhmmm going to try this me thinks.. as its giving me a head ake haha! it actually does sound like rubber on metal rubbing well exactly what my mate said when passenger!on all coils? Quote Link to post Share on other sites
Bryan-4E-FTE Posted January 4, 2013 Share Posted January 4, 2013 Got tein coilovers.All rubbers are good and no bolts are lose.I dont get it -.-" Quote Link to post Share on other sites
td04 turbo Posted January 4, 2013 Share Posted January 4, 2013 Have u got polly bushes on rear? Quote Link to post Share on other sites
micky boy Posted January 4, 2013 Share Posted January 4, 2013 On your bothers Glanza its always made that noise! And its the rear shocks absorbing etc! Quote Link to post Share on other sites
iamlegend Posted January 4, 2013 Author Share Posted January 4, 2013 well ive greased the rear rubbers up on the coilovers and its helped so MUCH better! only soaked them in wd40 when i get the time gonna copper grease them Quote Link to post Share on other sites
micky boy Posted January 4, 2013 Share Posted January 4, 2013 well ive greased the rear rubbers up on the coilovers and its helped so MUCH better!only soaked them in wd40when i get the time gonna copper grease them Quote Link to post Share on other sites
little dave Posted January 4, 2013 Share Posted January 4, 2013 i had this same problem with an old car i copper grease the shit out of everything now lol Quote Link to post Share on other sites
StuDoc 72 Posted January 5, 2013 Share Posted January 5, 2013 Youd be better off with white spray grease, copper grease will work perfectly but the copper is added to resist heat and just makes right mess when its not completely necessary.If you use it for this it will work fine but will just make it more hassle ud be far neater and less hassle using white spray grease just a little tip. Quote Link to post Share on other sites
iamlegend Posted January 5, 2013 Author Share Posted January 5, 2013 Youd be better off with white spray grease, copper grease will work perfectly but the copper is added to resist heat and just makes right mess when its not completely necessary.If you use it for this it will work fine but will just make it more hassle ud be far neater and less hassle using white spray grease just a little tip.Will do this then mate Cheers for that as yes makes sence as its a spray so be easier .. Quote Link to post Share on other sites
