davehart Posted January 4, 2013 Posted January 4, 2013 I managed to get a cheap Japspeed system last year to replace my old system as it kept knocking on the rear axle.The Japspeed system does the same thing but worse, I don't know if its because they are poorly made but there are a few Starlets out there with this system so they can't fit that bad?It's on the rear section with the backbox, the loop over the rear axle just knocks on the frame with the slightest wobble. Bloody annoying!It's been off the road for a year and a bit and just got fresh MOT on it today so I had not a chance to road test it before today.Anyone had issues with these systems on EP82's and made a solution for it?Just need to tax it Monday and we have another EP back on the road Quote
morgey Posted January 4, 2013 Posted January 4, 2013 Wrap some heat wrap around it will make more of a thud that and clang that way lol Quote
turbo Grant Posted January 4, 2013 Posted January 4, 2013 Get the cable ties out and use them to adjust the position it sit in. Don't put them on the exhaust tho haha. Wrap them round the rubbers and you can put some rubber hose inside the rubber hangers to stiffen them up. That's what I done on my GT. but when it was wet it still banged a little. It bugged me so much once, I stopped the car in the rain and crawled under it to put some more ties on lol if you don't want too use cable ties you will need to get it tweaked with some gas Quote
DavidAshton Posted January 4, 2013 Posted January 4, 2013 Heat wrap as suggested, mine is an EP91 system and did the same, this sorted if for a while, then it stated hitting the rear beam so that's wrapped up too now! Quote
davehart Posted January 4, 2013 Author Posted January 4, 2013 Knocks and rattles just get on my tits, especially with the state of the roads around here.Might try the trusty cable tie approach or see about taking it to a specialist to modify it so its fits better. Quote
kbond Posted January 4, 2013 Posted January 4, 2013 I have this exhaust and ive done the same as above cable ties on the rubbers to stiffen it up and some heat wrap and now I dont here anything Quote
Foggy Posted January 4, 2013 Posted January 4, 2013 I had the same problem on my ep82. Few slaps of the hammer cured it. Quote
Liam_D Posted January 4, 2013 Posted January 4, 2013 My Buddyclub knocks too. Ive wedged more rubber between the rubbers and cable tied them up too! Quote
Amjad Posted January 5, 2013 Posted January 5, 2013 Duct tape fixes anything hahaI first heat wrapped the exhaust then duct taped some cushioning stuff to the axle, it's been fine for a few thousand miles Inc being on track and the exhaust temps getting very high! Quote
steve-gers Posted January 5, 2013 Posted January 5, 2013 I bought powerflex engine mounts and put cable ties round them. Totally cured it. Quote
rmsnoel Posted January 5, 2013 Posted January 5, 2013 (edited) you can try the round shaped rubber or poly exhaust hangers instead of the oval shape. hole centres are closer together and give it that little lift. I also bend.the front and maybe rear hangers using the ring of a spanner. dont use a hammer.It wouldnt be a starlet if the exhaust didnt bang.. Edited January 5, 2013 by rmsnoel Quote
davehart Posted January 11, 2013 Author Posted January 11, 2013 I've sorted the rattle. One very strong industrial cable tie on the inner hanger mount to hold it up a bit stiffer has done the trick! Maybe Japspeed should pack cable ties into their systems in the future Quote
Driver Posted January 12, 2013 Posted January 12, 2013 For some reason UKSO won't let me quote your 1st post Davehart but to quote 2 words in there "Cheap" and "Japspeed" There is your problems. 1, cheap.Buy cheap, buy twice. We all know this to be true. 2, Japspeed.Well that one just answers itself ! Quote
