hey from scotland
nah I've had it for nearly 2 years dude, i bought it from bristol with the bottom end knocking, since then its had a full rebuild and done just over 5k
the spec on the car so far is
4e-fte engine
fully rebuilt head with oem parts
forged pistons
h-beam rods
arp rod bolts
arp head studs
acl race bearings
act 6 puck clutch
log style manifold
ct9 turbo
straight through 2.5" exhaust
TRD coilovers
cusco strutbrace
drilled and grooved discs
ferodo brake pads
16" black rota gt3's with blue lip (not fitted to car yet)
this was the car hours after i got it
first mods i done was removed the HRF front bumper and fitted a oem bumper, fitted amber indicators and painted the wheels white
then it was time to remove the engine and get it rebuilt
and it looked like this after the rebuild
then time to build the car back up
and that was it for a while and now I've had the rocker cover redone
well its just laying there if anyone wants to make me an offer lol
I've just pulled it out the garage after it being tucked away since September but when i pulled it out the other day and there's something wrong it i have an engine managment light on and it wont rev past 4k rpm, its fine bellow 4k but when i try rev past it i just get loud pops and bangs with black smoke and a strong smell of fuel so im going to find out what the code is tomorrow when i have daylight.
my plans this year is to get the following
ramhorn manifold
garrett gt28
3" full exhaust system
decent engine management
get a set of toyo r888's for the rota wheels i recently got for it
do something with the gearbox because before i took it of the road second gear started crunching slightly
  On 2/5/2013 at 9:44 PM, Chris_GlanzaV98 said:
Awrite Daryn welcome to the forum !
Clean looking V there mate ! engine looked great when you were about to drop it in !
hopefully see you at a meet pretty soon when the weathers better and everyones up and running again !
hi mate, thanks :) yeah i was almost afraid to put it in lol yeah hopefully i will make a meet when the weather clears up as its just terrible at the moment
ramhorn manifold
garrett gt28
The cam sensor will be fucked, need to change the distributer as its part of that., had same problem years ago took me weeks to figure out what was wrong.
Swap you a working dizzy for hrf bumper? Haha
well I've just got a new dizzy cap and rotor arm so al put that on tomorrow n give it a try but if i have no luck il swap u
the bumper is needing a sand down and re-paint, thats the reason i took it off
