Its an awesome price even if it needs a rebuild still worth it. I sold my old toytuning for £200 when I went TD04 was a good turbo though, nice hybrid.
You can buy rebulid kits for £60-80 and if you have a decent level of mechanical knowledge then its easy enough to do yourself, plenty of video guides on youtube.
the original toytuning hybrids were hi-flow, turbo dynamics make hi-flow turbos also,
it all depends how bad the shaft play is if it moves enough to touch the sides of the housing it will defo need rebuilding before you use it but if its minimal movement I wouldn't bother chances are youll change plans a year or two down the road
all depends on your plans buddy
I've just checked again and the compressor wheel is touching one of the sides so will need a rebuild, so will order a rebuild kit up and get it done I'm goin to forge it once this engine dies so plans will soon change and hawwy there me work socks lol
Yeah you can see a groove in the compressor houseing where the compressor wheel has been catching!!! And yeah its deffo a hiflow turbo
29387D05-9FDD-49E5-A85E-6496E5B76CEB-424
who's the seller that sold it too you??as above turbodave is a old member off here who ran awesome power through his i also had one on mine when i bought it ryanlang now runs it he also had something to do with the supply of toytuning hybrids.. :)
Don't know who the seller was it was someone on eBay I have read up about turbodaves on google from the other forum am gonna price a repair kit up and go from there
can give you his name if you wanna contact him for a rebuild kit dude doubt it'll be cheap though as i looked into it before might be worth a try if your interested gimme a pm
its defo a hybrid... different comp wheel, cut back blades on exhaust wheel and ported wastegate.. looks like an early fensport hybrid... they always cut back the blades on the exhaust wheel
