EP-Azz Posted March 17, 2013 Posted March 17, 2013 (edited) Hi lads, had the emanage fitted yesterday along with afuel pump at tuning developments and car made 196.5@0.85 bar however the boost drops, mike reckons if I had a decent boost controller I could get more power later in the revs as it drops off from 1.05 bar to 0.85 , its running a ct9 hybrid what you reckon ? Edited March 17, 2013 by EP-Azz Quote
TrisK Posted March 17, 2013 Posted March 17, 2013 Very good figure from that boost level dudeWould be chuffed with that Quote
EP-Azz Posted March 18, 2013 Author Posted March 18, 2013 Cheers mate , hopefully if I can get the boost to hold after it drops at about 5750 it will make over 200.....ebc should do it I hope Quote
Matt1878 Posted March 18, 2013 Posted March 18, 2013 Nice result! Very Interested to see the result once you got the boost sorted! What hybrid you running? Quote
EP-Azz Posted March 18, 2013 Author Posted March 18, 2013 Its a ct9/ct12/ct20 that keirz built when he had it ,hope fully by chnaging the spring in the wastegate n using an ebc that will sort the boost Quote
starletburkie Posted March 18, 2013 Posted March 18, 2013 you sure youv no split ic pipes? looks like it will make good power if it held boost Quote
EP-Azz Posted March 18, 2013 Author Posted March 18, 2013 Ill have to look, mikes convinced its the controller though! Quote
Socks Posted March 18, 2013 Posted March 18, 2013 put it this way... a decent ebc wont make it worse ;) Quote
EP-Azz Posted March 18, 2013 Author Posted March 18, 2013 Exactly, I just want it holding more, hes allowed for it on the map so if I can get it holding more in that rev range it should be fine and make more power......gonna change the wg spring to just incase that's interfering...what's a decent ebc? Apexi avc-r ...... Quote
Danb Posted March 18, 2013 Posted March 18, 2013 ...what's a decent ebc? Apexi avc-r ......blitz spec r - job done Quote
Liam_D Posted March 18, 2013 Posted March 18, 2013 Decent boost controller is whats needed mate! Quote
EP-Azz Posted March 19, 2013 Author Posted March 19, 2013 Just a manual SPEC R boost controller .... Better than a turbo smart but obviously not that good Quote
EP-Azz Posted March 19, 2013 Author Posted March 19, 2013 Na Keirz it was propa stiff n I couldn't get it to turn, I bought this one brand new too :/ u reckon that one you sent will be better? I'm defo gettin an ebc anyway Quote
keirz Posted March 19, 2013 Posted March 19, 2013 was just thinking that i never really noticed a problem with boost dropping off when i had it running a 1bar but maybe i just i just never watch higher up the rev range. good results really considering the boost issues. Quote
EP-Azz Posted March 19, 2013 Author Posted March 19, 2013 Yea I know , ill see what its like with an ebc and take it back to mike Quote
EP-Azz Posted March 24, 2013 Author Posted March 24, 2013 Irs an external gate mate 0.4 bar spring Quote
