Contents:
Page 1:
First Car | Build Start | Shots Of Her | 16" Rota Grid Drift | Wheels Refubished | Engine Bay Shot | Tyres Refitted | Wheels On | Old Engine Out | Apexi Power Fc | New Fully Forged Engine | New Rocker Cover Gasket & Seals Fitted | Rear Beam Removed | Bits Ready To Be Powercoated | Polished Rad | Spec 6 Clutch | Powerflex Bushes | Powdercoated Bits Back | Powerflex Rear Beam Bushes Fitted | Powerflex Engine Mount Bush Fitted | Sump Refitted | New Bottom Ball Joints | New Waterpump | Super Pro Front Arm Bushes | D1 Spec Wheel Nuts | Tanabe Shocks Refurbished | Powdercoated Rear Beam Refitted | New Rear Wheel Bearings | Powersteering Pump Painted | Powersteering Pump Pulley Painted | Whiteline 24mm Front Anti Roll Bar | Whiteline Adjustable Panhard Rod | Whiteline Rear Anti Roll Bar | Powercoated Bottom Arms Fitted | Whiteline Front Anti Roll Bar Fitted | Bottom Ball Joints Fitted | Tanabe Rear Shocks Refitted | Gearbox Refurbished | Powersteering Pump & Pulley Refitted | Powerflex Gearbox Bush Fitted | Aeromotive Fuel Lab | Zisco Performance Fuel Rail | Fuel Rail Test Fit | Private Registration Plate | Apexi Avcr Black Edition | Undersealing | Dash Removed | Rear Anti Roll Bar Fitted | Engine Bay Tidy | Powdercoated Hubs & New Bearings | Car Clean | Gearstick Extension Fitted | Painted Bits | Flocked Dash |
Page 2:
Rear Sound Proofing Removed | Gearbox Mounted To Engine | Built Not Bought Sticker | Wide Wheels | Rear Calipers Painted | Alternator Painted | Cars At Body Shop | Cruise Gearknob | Painted Starter Motor | Cylinder Head Painted | Rad Painted | Engine Shot | Painted Intercooler | New Clutch Slave Cylinder Fitted | Playing With Carbon Wrap | Body Shop Photos | Harness Screw Eyes | My Collection Of Parts | Zisco 6 Point Rear Strut Brace | Zisco Front Strut Brace | Roose Motorsport Hoses Cleaned | Heater Matrix Removed |
Page 3:
Rocker Cover Powdercoated | New An-10 Fittings | Hel Braided Clutch Line | Engine Photo | Body Shop Photos | Dirty Rotas | Carbon Din | Zinc Coated Nuts & Bolts | Zinc Coated Oil Filter Bolt Fitted | More Body Shop Photos | More Zinc Coated Nuts & Bolts Fitted |
Page 4:
Carbon Din Mounted | Old Carpet Removed | More Zinc Coated Nuts & Bolts Fitted | Air Conditioning Blanking Bung | Powdercoated Front Cross Bar | Powdercoated Bits Back | Powdercoated Rear Brace Mounts | Powderocated Gear Linkage Bracket Fitted | Powdercoated Fuel Filter Clamp | Custom Alloy Catch Tank | Door Locks Removed | Driveshafts Stripped | Cv Joints Painted | Car In Primer | Ash Catch Can Breather | Interior Primed | Engine Bay Primed | Paint Mixed | Car Painted | Photos Of Banzia Feature 2007 |
Page 5:
Cars Home | Cherry Glazed Engine Bay | Zisco 6 Point Rear Brace Fitted | Cruise Gearknob Fitted | Harness Screw Eyes Fitted | New Carpet In | Powderocated Rear Brace Brackets Fitted | Late Spec Rear Lights Refitted | Door Handles Refitted | Some Shots | Painted Steering Rack | More Zinc Coated Nuts And Bolts Fitted | Driverside Seat In | Rear Engine Mount Fitted | aerocatches | More Stuff Back From Body shop | Tailgate, Bonnet, Refitted | New Windscreen | Windows Refitted |
Page 6:
Flocked Dash In | Zinc Coated Dash Bolts Fitted | Aerocatches Fitted | Gauge Pod Fitted | New Nuts & Bolts | New Track Rod Ends Fitted | Photo Inside car | Private Plate On | More To Be Zinc Coated | Carbon Bonnet Dampers | ABS Removal Kit | Bonnet Dampers Fitted | Rear Bumper, Front Bumper, Sideskirts & Mirrors Back From Bodyshop | Fog Lights Mounted | Powdercoated Cross Bar Fitted | Epic Front Shot | Fuel Tank Removed |
Page 7:
More Powdercoating Done | Powdercoated Engine Mount Fitted | Powderocated Inlet Manifold Bracket Fitted | Engine Bay Waxed | More Underseal | Engine Damper Fitted | Rear Engine Mount Bracket Fitted | Engine shots | Engine Fitted |
Page 8:
Fuse Box Mounted | Fuse Box Cover Painted | Stick On Front Number Plate Fitted | Rear Template Made | Braided Fuel Lines Fitted | Gauges Wired In | Fuel Lab Mounted | Miester R Coilovers | Scuttle Panel Refurbished | Tailgate Struts Refurbished | Arial Painted & Fitted | Cleaning Session |
Page 9:
More Car Cleaning | Apexi Avcr Wired In | Civic Rad Bracket Mounted | More Zinc Coated Bits | Zinc Coated Door Catches Fitted | Shot Underneath the car | Rota Grid Drifts Refurbished | Zinc Coated Master Cylinders Fitted |
Page 10:
Wheels Waxed | Powdercoated Wiper Arms | Powdercoated Drive Shafts | New Cv Boots | Fuel Tank Painted | Drive Shafts Rebuilt | Fuel Tank Refitted | Ukso Sticker On Rocker Cover | Titan Race Gearbox oil | Blue Rocker Cover Nuts |
Page 11:
Rocker Cover Nuts Fitted | Engine Damper Bracket Modified | Turbosmart Oil Cap Polished | Prosport Gauges | Powdercoated Engine Damper Brackets | Exhaust Heat Shield Removed | Prosport Gauges Fitted | Engine Damper Bracket Fitted | Custom Powersteering Tank | Smoothed Rocker Cover |
Page 12:
Custom Powersteering Tank Mounted | Loom Removed | Zinc Coated Exhaust Heat Shield |
Page 13:
Zinc Coated Exhaust Heat Shield Fitted | Wiper Motor Painted & Fitted | Wiper Arm Fitted With New Blades | Scuttle Panel Fitted | Welded An-10 Fittings Onto Rocker Cover | Corbeua Revolution Carbon Kevlar Seats |
Page 14:
Corbeua Side Mounts | Yokohama Ad08s Fitted | Rear Grooved Discs Arrived | K sport 286mm 6 Pot Front Brakes | Carbon Fibre Cut Outs Made | K-Sports Sanded Down |
Page 15:
Seat Runners Arrived | Rear Car Shot | Plastics To Be Carbon Dipped | New Headlights | New Ebc Rear Brake Pads | New Headlight Adjusters | 6 Piece Braided Brake Line | Oil Filter Sandwich Plate | Rocker cover & Zisco Fuel Rail Mirror Polished |
Page 16:
C's Short Shifter | K Sports Painted | Rocker Cover Refitted | Headlights Fitted | Hks Oil Filter | Motec M400 | Cruise Rep Wings | Custom Motec Harness | K-Sports Fitted | Engine Bay Shot | Cruise Wings Test Fit | Oil Sandwich plate & Filter Fitted | Loom Stripped | Major Clean | Ap Racing Brake Fluid | Rear Light Wire Tuck |
Page 17:
New Battery Clamp | Rear Calipers & Carriers Stripped | Painted Calipers | Polished Handbrake Springs | Zinc Coat Strut leg Bolts | Wepr Teaser Photo | GTx3076r | Rota Gt3 16" Refurbished |
Page 18:
Solid Shifter Bushes | H&R Hubcentric Spacers | Wheel Problem | Car Clean | Polyurethane Cv Boots
Page 19:
Flocked Dash Out | New Alarm System With Remote Start | Fusebox Relocation | Wire Tidy | Custom Oil Catch Can | Custom Fuel Tank | New An-10 Fittings | New Fittings & Hose For Fuel | Facet Fuel Pump | Bosch 044 | Fuel Pumps mounted | Oil Catch Can Mounted & Plumbed In |
Page 20:
Stripped Out Rear Porn | Manifold Getting Made | Powdercoated Black Rota Gt3 Alloys | Poliahed Custom Tanks | Sparco Quick Release Boss | Race Inlet Photo From Wepr | Intercooler Photo From Wepr | My Order On Wepr Engine | Metal Polished Porn | Custom Swirl Pot | Swirl Pot Polished |
Page 21:
My Wepr Order Fully Polished | Making Braided Fuel Lines | Custom Swirl Pot Mounted | Engraved Inlet Photo From Wepr | Rear Window Problem | H&R Rear Spacers | Powered By WickedEp Racing Sticker |
Hello lads,
Back in September it was time to get a car I have always had a soft spot for, so after looking for some I found one what caught my eye, so got on the phone and arranged to go and view, after a 3 hour drive there, it was time to find out some more info on it after reading through a folder full it was time to hit the road, so off we went, everything seemed to be ok, :) anyway driving slowly for a little while the lad i got it from decided to give it a little to say the least i was pinned back in the seat and smiling ear to ear :) going from a corsa 1.2 sxi to this was an amazing feeling, well after he showed me what it went like he said i could drive, automatically getting into the drivers seat i went to move the seat forward but they were fixed luckly it was perfect where it was :) anyway I fell in love it was coming home with me :p after coming back down the motorway will boosting noises I just couldn't stop smiling, after getting the car home and driving it for a short period of time i knew where i wanted to go with it, so this is where the build began, :) Im around 4 months into the build so i think its time i start a build thread but its still only early days!
A photo of my corsa (first car)
Over this weekend im going to upload everything to where i am now with it!
Anyway here is a couple of photos of my V not long after i got it :)
Car Spec when I got it:
Gabb shocks and springs lowered to a reasonable level
Greddy strut braces front and rear
Decat straight through system (BUDDY CLUB)
Relocated Air Filter to front bumper (HKS)
Front Mounted Intercooler (HDI REP)
New HT leads (Ultra)
Uprated Fuel Pump (WALBRO)
Uprated Front Disks (Grooved)
Front and Rear Strut Braces (GREDDY)
Uprated earth kit
Oil catch can
Securion harnesses
Corbeau forza bucket seats
BOV (FORGE)
Full Silicone hosing kit
Carbon fibre rear splitter
Carbon fibre mid spoiler
Carbon fibre top spoiler
JAM eyebrows
MOMO wheel and boss
DEZENT alloys
Turbosmart oil filler cap
Civic alloy rad
Exedy clutch
Edited by JordanEP91
  • Replies 1k
  • Created
  • Last Reply
Top Posters In This Topic
so one of the first things i got was some new wheels ;) when i bought them they were white but heres a photo after they been dipped
got my rota's on back and on ;) rather low ;) doesn't normally sit this low its just because the fronts jacked up :)
well it was my day off work so my next job was to get the old engine out, doing this for the first time on my own on a stoned drive was abit of a pain but I managed :)
after looking for a fully forged engine for ages i was going to have one built then this popped up so i had to have it, when i got the engine the rocker cover was black and the paint started to flake the the first thing i done was take it off and got a friend to powdercoat it for me, before refitting it I fitted new spark plug tube seals and a new gasket :)
Engine Spec
265 Billet cams
Knife edged and balanced crank
Ported and polished head
Zep 2mm headgasket
Arp bolts
10cc dished pistons
Scat rods
Wiseco pistons
The engine was built by tm-developments
nicee .. where did you get that oil filler cap ?
thanks, it was on the car when i got it mate, when i got the forged engine it come with a red one but i got rid off that, im not sure where they can be bought from sorry
whilst i gave all these bits to a friend to be coated everything pretty much come to a stand still till i got the stuff back anyway so i done a bit of polishing ;) with a bit of autosol come up like new
not long after giving my parts to a friend to be coated they were back so i could crack on and get some stuff done :)
looking nice and fresh
well now my bits were back it was time to fit the new powerflex bushes and fit parts back on the engine and the car :)
