I just realized that whiteline has a dealer in the us which makes life wonderful for me as i can get shipping done for next to nothing...
so im about to order my full under body suspension...
can you guys give me some insight as to which ones to choose as i dont know the differences in the sway bars ... im assuming the thicker bars are more stiff so less roll?
and then there is the rear sway whats the difference between the adjustable and non adjustable... i mean obviously one can adjust but is it necessary?
this is the website so you know what im talking about as well as for all the people in the caribbean that need stuff as shipping is WAY CHEAPER FROM THE STATES
http://www.whitelinesuspensionparts.com/products.asp?cat=Toyota+Starlet+1993
AdamB your up ... bring forth answers
Thinker ARB up front decrease the chance of roll but may increase the chance of understeer.
Adjustable ARB at the back is not necessary, ask anyone with an adjustable RARB how often they adjust it. Save a few quid :)
IMO, make sure your ball joints, bushes etc. are in good condition first, then go for,
RARB non adjustable
ALK
Poly bush everything
Any rear strut brace and C pillar bar
In that order, the rest isnt a must IMO.
already have the c pillar and the rear and front strut braces and everything is already polly bushed...the roll cage is also already in production
I am about to purchase the RARB and FARB .. so screww the adjustable but which of the 4 different FARBs do i get the one with the linkages and shit i assume?
the anti lift kit makes sense as well you say?
Edited by rasslenny
and which FARB am i looking at... the ones that come with all the linkages i assume.. so 22mm with all the bells and whistles?
Edited by rasslenny
i did but about a year and a bit ago and i track the shit out of the car and had to polly everything a few months ago .. those however did not change ..... and the car is lowered quite some so i should look into an adjustable pan hard rod shouldn't i
As everyone has said above about the setup really.
Although the difference in mm with roll bars is not the thickness, its the distance between the bush mounting and the drop link connection point. The closer the drop link to the bush, the stiffer it is, the further away the softer it is.
Upto you if you want an adjustable one really, if your going to be using the car as a circuit car then everything you can adjust always helps with the setup till you find something you like.
Adjustable reat antiroll bar is only 10% more than the fixed one and will allow u to adjust for other mods to find that neutral handling. I adjust mine anytime I change tyre brands, alignment or from wet to dry season.
Panhard rod will let u centre up the rear axle to have your car deive straight n true but best of all your back end wont twitch under very hard cornering when u near the limits of grip.
The antilift castor kit will take the lightness out of the steering at speed. I loved it on my old car as max castor made the steering centre up again like a kart but now it just pisses me off at the level of effort needed to steer the bitch.
My advice is start at the rear and work your way forward
If you read whiteline's own website youll see they say the adjustable rarb is needed. The fixed one is for aus cars that didnt come with a farb...
the first bars i was going to get was panhard and RARB just didnt know which to get as they seemed like small differences that would make a diff... and thanks to all of you im pretty sure i know what makes the most sense now
adjustable 22 mm RARB with all the drop links and what not
adjustable panhard rod
and antilift kit
Agree with this, the anti lift kit is a bit of a personal preference thing, you have to try it for yourself, what works for one driver may not work for another.
On the front ARB it is thickness
Absolute garbage! Its the thickness of the bars front and rear.
On the front it is because tis fixed. Why don't you check out the whiteline website and do some research before typing and making yourself look like a cock :thumbsup:
http://www.whiteline.com.au/docs/bulletins/BL-281.pdf
Yes the thickness of the bar does make a difference, but also the material and grade of the material also makes just as much if not a bigger difference.
Edited by AdamB
Or I could phone and ask them like I did?? To avoid looking like a cock :thumbsup:
Why would you make an expensive phone call to Australia when all the information is publicly there to see as made clear by the manufacturer.
They have a branch in Scotland.
The comment was also that the 22mm does not represent the thickness of the bar..... which it does.
Edited by StuDoc 72
I'd reckon the big give away on that link would be the title sway bar DIAMETER conversion chart.
Where you get confused is the part where that video uses the holes and says that changing the distance is 23-24-25mm.
This means moving it closer obviously increases the tension and causes the bar to ACT like it is infact a thicker bar as this is whole point of the adjustability, it allows you to change your tension so the middle hole in a 24mm bar is the standard hole moving it closer increases the tension causing it to act like a 25mm bar.
Put your hand under your elbow and get someone to push down on the free hand....your arm will straighten out. Now hold your wrist and get someone to push down on your free hand....its more difficult to do so. Theoretically this is what the adjustment achieves.
Stick to your Haynes manual cock boy ;)
Think you should be doing this Adam mate.
well that escalated quickly.... its is blatantly clear that the mm reference as stated by the website defines the diameter size of each bar...AND also the resulted effect of changing the holes on the adjustable bars... making the bar theoretically a different mm size :db:
sooooooo having settled that everyone is right .... SHAT THE FAKK UPPP LOL :thumbsup:
Edited by rasslenny
