mk1kurt Posted July 19, 2013 Posted July 19, 2013 Right guys can people post some pictures up of ther td04 kits please as i have a wepr evolution ewg kit and my screamer pipe sits about half an inch above my bottom radiator hose so soon as it gets onto boost would blast flames onto the rad pipe... I just want to see how other peoples kits fit Quote
mikey4410 Posted July 19, 2013 Posted July 19, 2013 easyiest way ,simply strap the hose just out the way slighty,just enough to clear it by a cm just to be on safe side. cable tie it lighty out the way hoses fit one way really,maybe get some pics up of ures Quote
Liam_D Posted July 19, 2013 Posted July 19, 2013 is the wastegate sitting at the right angle? Mines a good few inches off my rad hose. it was a problem when i tried fitting a Civic rad though, Quote
TrisK Posted July 19, 2013 Posted July 19, 2013 If you have a civic rad then the bottom hose is on the other side Quote
mk1kurt Posted July 20, 2013 Author Posted July 20, 2013 Yeah had a look at a few pictures and i do have a civic rad but my civic rad bottom hose is right next to my downpipe i need another rad or screamer out the bonnet ;) cheers guys thanks for all the help Quote
TrisK Posted July 20, 2013 Posted July 20, 2013 Yeah had a look at a few pictures and i do have a civic rad but my civic rad bottom hose is right next to my downpipe i need another rad or screamer out the bonnet ;) cheers guys thanks for all the helpOr get the rad outlet rewelded on the other side Quote
akyakapotter Posted July 20, 2013 Posted July 20, 2013 That's what I done had the out let moved to the other side of my civic rad Quote
Liam_D Posted July 20, 2013 Posted July 20, 2013 ^^^ This is the best thing to do, get Dean @ RWDevelopments to do it! Quote
mk1kurt Posted July 27, 2013 Author Posted July 27, 2013 Good idea yeah al get that done asap thanks lads great problem solving Quote
Socks Posted July 27, 2013 Posted July 27, 2013 Are the WEPR kits not designed to work with civic rads... Or stock rads? Quote
Glanza-Ben Posted July 27, 2013 Posted July 27, 2013 Screamer out the bonnets the way forward, here's my mates road legal drifter with it Quote
EP-Azz Posted August 6, 2013 Posted August 6, 2013 I'm gonna have same problem I think, liam put up a pic of how yours sits because my external will be by the engine rocker with a long stainless screamer going down will that interfere with the rad? Quote
wickedep Posted August 6, 2013 Posted August 6, 2013 our kits are designed to work with stock radiator. if you are using a civic radiator then the bottom port has to be moved like akyakpotter has done. this brings the bottom port to where it is on the stock radiator. you do get civic radiator variations with the bottom port already on the passenger side...with these no mods will need to be made. the 3-core on my car is such a variant. Quote
EP-Azz Posted August 7, 2013 Posted August 7, 2013 I cba with moving the port over, dean you should do this as a fix if anything, I'd buy one already done straight away! Saves loads of hassle Quote
Johnny Posted January 20, 2016 Posted January 20, 2016 Useful post. I found the same problem with the WEPR kit and Civic Rad. But, got my Outlet re-welded same as above. Easily done Quote
