threehundred Posted September 24, 2014 Author Share Posted September 24, 2014 before I forget... can anyone recommend an uprated gearbox mount? mine still runs the original and there is a LOT of engine movement under load. cheers. Quote Link to post Share on other sites
Glanza-Ben Posted September 24, 2014 Share Posted September 24, 2014 Shame to see this one's gone bang Quote Link to post Share on other sites
iamlegend Posted September 25, 2014 Share Posted September 25, 2014 Like said in text mate I CANT believe it!! wow and yes 1 year gone so quick its crazy how time has went this fast! anyways yes I spent alot of £££ on this build as you can see as you have all my receipts lol...for it to have problems 1 year in is errmmmmm pretty shit tbh.... glad you have got it sorted thow nice to see its getting the tlc it needs!!! "Just finished off a Toyota Glanza today that came in as a non runner with none or little compression across the board. removing the head showed an inlet valve stuck wide open , this was caused by damage to the follower sleeve inflicted by a valve spring compressor, the rest of the missing compression was caused by lack of valve clearances [engine only done minimal mileage since its build] the worrying thing we found was 2 valve shims adjusted to fit with an angle grinder!! to cut a long storey short with lots of tlc and care , the engine is back together and runs like a watch..dyno tomorrow.."" THIS SCARES ME!!!!!!!!!!!!!!!!!!! Quote Link to post Share on other sites
5e colin Posted September 25, 2014 Share Posted September 25, 2014 (edited) nooo freaking way man thats an utter COWBOY job on the shim !!! there only a 10ner in toyota for all sizes wow this baffles be EDIT: get them pics up soon bean waiting a year now :) Edited September 25, 2014 by 5e colin Quote Link to post Share on other sites
threehundred Posted September 25, 2014 Author Share Posted September 25, 2014 On 9/24/2014 at 8:53 PM, Glanza-Ben said: Shame to see this one's gone bang it didn't fully go bang, it just needed a bit of work to get it going again! Quote Link to post Share on other sites
iamlegend Posted September 25, 2014 Share Posted September 25, 2014 I CANT get over this like haha jesus imagine if i still owned it keep thinking!!! that valve is ridiculous I want to hear TD reply about this like really man.... i just dont get it Quote Link to post Share on other sites
Ollieh17 Posted September 25, 2014 Share Posted September 25, 2014 Bloody hell!! You're gonna upset some people on here with those TD findings Quote Link to post Share on other sites
Matt Heard Posted September 25, 2014 Share Posted September 25, 2014 I really do hope this is a one off and TD or whoever is responsible has a valid excuse.Just glad to know the cars back on the road and done to a good high quality standard that Quest Motorsport always provide. Quote Link to post Share on other sites
jayc-glanza17 Posted September 27, 2014 Share Posted September 27, 2014 ah I remember this car now.. colin at atspeed had on dyno some time back.. map was lean top end I remember him ringing me up to come and have a look.. glad its being sorted now matey.. Quote Link to post Share on other sites
threehundred Posted September 30, 2014 Author Share Posted September 30, 2014 here is the report I got back from Quest Motorsport today, have a read... "Received car in a non running condition. On trying to start the car it was very apparent that there was a compression problem. 1. carry out compression test , found pressure of 45 , 0 , 60 , 150 psi respectively from cylinder 1 on wards. 2. carry out cylinder leakdown test to determine if the problem was head or block related , cylinder leakage was 75 , 100 , 70 , 20% respectively from cylinder 1. 3. remove cylinder head , first observation head torque was no where near the 60 ft lbs specified by ARP. Once head was off it was also noted that some of the head bolt washers where in correctly fitted.The no 5 inlet valve was stuck wide open causing the zero psi compression reading on cylinder2, the valve closed when tapped with the handle of a screw driver and did not appear to be bent. 4. all valves removed and checked for damage non where bent or damaged , but the cam follower on the no5 inlet valve on cylinder2 would not come out freely and once removed it could be seen that the bore the cam follower travels in was damaged causing the valve to stick in a certain position, the damage could have been caused by a valve spring compressor. The damaged bore was cleaned up and checked that the follower moved freely in all positions with out sticking. 5. all valves lapped in with minimal effort and vacuum checked for leakage on the bench , the head was re assembled with new valve guide seals and up rated valve springs, valve clearances were then checked , it was found all inlet valves had minimal clearance of less than .002" , all exhaust valves except 1 were below bottom limit clearance.All valves re shimmed to give top limit clearance. 6. cylinder head re installed with new gasket after a leakage test was carried out on the pistons half way down bores, this confirmed there was no by pass, head bolts re torqued to the correct 60 lbs ft in 3 stages , then repeat sequence before cam cover was replaced.New cam belt kit installed . 7. Remove exhaust manifold as it had been blowing badly , this was refaced , also the poor quality of the manifold was addressed and all internal welds from the waste gate port and collector were dressed to removed break through and all restrictions,refit manifold. Prime oil circuits to turbo and internals ready for starting. start engine and run up to temperature, electric fan working ok . Road test car and check for any oil and water leaks. Dyno check car for boost control and AFR's, AFR's were acceptable across the rev range. it was not safe to carry out continuous dyno runs due to the poor lower gear box mount causing excessive engine movement. Engine cold start and general running now very good , vehicle returned to customer." Quote Link to post Share on other sites
Gainzy Posted September 30, 2014 Share Posted September 30, 2014 Poor quality of manifold? Sure it had a wepr set up on that? Jesus that's a lot of work from a new engine... Quote Link to post Share on other sites
Glanza-Ben Posted September 30, 2014 Share Posted September 30, 2014 On 9/30/2014 at 5:23 PM, Gainzy said: Poor quality of manifold? Sure it had a wepr set up on that? Jesus that's a lot of work from a new engine...Was just thinking the same about the mani I'm shore a wepr is lifetime guarantee and have never seen one fail my self Quote Link to post Share on other sites
iamlegend Posted September 30, 2014 Share Posted September 30, 2014 that indeed was a brand new WEPR manifold!!!! that list is a joke name and shame that shit like!!!!!! disgusted Quote Link to post Share on other sites
threehundred Posted December 11, 2014 Author Share Posted December 11, 2014 Anyone know of a good auto electrician in Essex area? A few electrical gremlins have surfaced recently... 1) No rear lights. Brake lights and indicators seem to be ok but nothing else (including fog and reverse)2) Dash has stopped lighting up.3) No side lights, only main and full beam are working. Perfect timing for the winter nights Quote Link to post Share on other sites
jellybaby Posted December 12, 2014 Share Posted December 12, 2014 check ya fuses should b a 20 amp fuse in the fuse bay in the drivers side of the dash below the steering wheelwould say come up to colchester as i auto electrictin also had my starlet 6 years and used to help at tmd when they was running Quote Link to post Share on other sites
threehundred Posted May 11, 2015 Author Share Posted May 11, 2015 On 12/12/2014 at 4:39 PM, jellybaby said: check ya fuses should b a 20 amp fuse in the fuse bay in the drivers side of the dash below the steering wheelwould say come up to colchester as i auto electrictin also had my starlet 6 years and used to help at tmd when they was running Thanks fella, might take you up on that. still havent got it sorted but to be honest I havent looked at it again since last time. Quote Link to post Share on other sites
threehundred Posted May 11, 2015 Author Share Posted May 11, 2015 My Glanza is going up for sale soon, just putting the word out there for now. Will start a proper for sale thread soon and get some fresh pics up. Cheers Quote Link to post Share on other sites
Calum122 Posted May 11, 2015 Share Posted May 11, 2015 She been good to you whilst you've had it? I read you had a few problems but is that all sorted now. Quote Link to post Share on other sites
jimmymac101 Posted May 11, 2015 Share Posted May 11, 2015 Finally had enough then ? as above did the problems ever get sorted ? James Quote Link to post Share on other sites
jellybaby Posted May 11, 2015 Share Posted May 11, 2015 U selling or breaking buddy ??? Might b intrested in someBits also I willing to help you out with the above problems of u don't sell or break Quote Link to post Share on other sites
threehundred Posted June 22, 2015 Author Share Posted June 22, 2015 On 5/11/2015 at 9:47 AM, Calum122 said: She been good to you whilst you've had it? I read you had a few problems but is that all sorted now. yeah very good, apart from the blip mentioned above! all got sorted though. On 5/11/2015 at 9:50 AM, jimmymac101 said: Finally had enough then ? as above did the problems ever get sorted ? James I need something bigger and more practical. yeah everything was sorted by Quest Motorsport last September, it's been fault free since! On 5/11/2015 at 10:46 AM, jellybaby said: U selling or breaking buddy ???Might b intrested in someBits also I willing to help you out with the above problems of u don't sell or break strictly selling as a whole car fella, no time to break or be left with a rolling shell that nobody wants! Quote Link to post Share on other sites
