  • Replies 68
  • Created
  • Last Reply
Top Posters In This Topic
i'm currently in the collection phase for my forged 5e build.
would like to have your opinions on the setup i have in mind and any sugestions or tips you might have.
i have a spare 4efte engine for parts.
5e bottom end with good crank
5e scat rods
5efhe cams
Gt2560r turbo
wepr mani + downpipe externally gated
arp headbolts
460cc injectors
3 puck trd clutch (will this suffice around 300bhp?)
microtech lt8 standalone
the questions i have:
pistons, what will you guys suggest? wiseco? wossner? something else? and why? :)
what headgasket? athena 1.2mm? if yes, why? :)
any need for a custom intake or will stock do the job?
any need to switch to individual coils?
any other thoughts on the setup?
Edited by PureRage
  • 2 months later...
was having some problems with the hood locking mechanism lately and the hood didn't line up right the right corner always stood up a bit and never could figure out why.
also, the support that holds it in place was preventing me from fitting the intercooler nice and flush against the beam behind it so i wanted it out off the way.
the simple sollution was fitting cheesy hood pins.
not everyone's cup of tea but this is a pure function over form mod for me
it was quite hard to line everything up correctly and then that awkward moment of putting a drill through the hood and cutting massive holes in it...
results:
  • 3 weeks later...
  • 3 months later...
Right, let's blow some dust off this topic :)
Have been tinkering with the car (as usual)
last march i was at the drags and i encountered a few minor problems.
she was smoking blue, likely causes were valve seals.
she was leaking a bit of oil around the crank seal on the box side. meaning i would have to take off the gearbox.
and i wanted to swap out the engine loom as it had been hacked and slashed multiple times over the years for various mods and it was giving me all sorts of grief.
so, let's take her apart again :)
Messenger_5855737809412707178_1396116688
en yes... it failed :p
engine out
and yup, seals...
i'll never buy imitation crap again!
prepped the shop for engine surgery
bought a few new goodies
oem seals!
strip it!
and yups, she used oil
cleaned :)
head dismanteled
and yup... crappy seals... meh
fiddely work to put it all back together again
new crank seal
nearly rebuilt
wires....
added the oil cooler
mostly back together again
coolant bottle, because racecar
running again :) last bits to button up
and at the track 2 days after the rebuild :)
did about 15 oval laps and 60 drags, held together quite well :D pleased with the results
replaced the rear wing :)
  • 3 weeks later...
removed all the broken and crappy smoked gauges and replaced them with clear white ones with peak warning.
glad to have working info on the engine again :) didn't feel good to race around not knowing oil temp/pressure etc.
lights on:
Last weekend we had a dragweekend for the dutch drags championship.
dragracing is still rather small in the netherlands so we are racing on an airfield. Hope we will onde day have a dedicated dragstrip near here.
Had great fun at the strip though!
Arrived at the strip on friday night. set up our caravan and prepped the car
Saterday morning was tech inspection time. passed with flying colors and i parked her at the starting grid wich was still a little bit empty :)
our neighbor, a v8 wakeup call works rly rly well :D
and more big toys
v8 escort! epic thing!
1000hp quatro anyone?
all great stuff but not the class i was driving in. me and the missis were running in the DSL class. meaning 15 seconds and over. The car ran quite a bit faster than 15 seconds but coulden;t reach the 14 yet. so decided to stick with out class and run her smoothly to just hit 15 sec.
after saturdays qualifying me and my wife were just 0.001 seconds apart!
we placed 3rd and 4th in our class and the top 8 went on for the elimination races. as me and my wife drive the same car this could pose a problem if we were to race against eachother. but that didn't happen so all was fine.
I failed in the semi finals and ended up on 3rd place.
my wife did better and ended up in the finals.
Unfortunatly she had a misshift into second gear and lost so ended up with 2nd place.
My wife in the final:
not bad if i do say so myself :)
  • 1 month later...
forgot to update this.
a while ago we had another drag day and me and my wife did well again :)
my wife took the first prize, there was no way for me to beat her time. we have to run 15 seconds and over, she put down a 15.001 and i placed 2nd with a 15.034
this puts us at the first and second place of this years dutch championship for our class :)
also just bought a gopro cam and tried it out for the first time at the track.
need to fix the wind noise though. the first run with the gopro on the dash was my wife's winning run.
the car should almost be rdy to run 14 seconds flat so we can move up a class but then we would lose the current championship points. so we'll hold off till next year and try to stay in the 15 seconds class.
https://www.youtube.com/watch?v=V6gIidY_18k&list=UUCCc-qKSO3vuL1n4vgm06HQ
  • 1 month later...
car made some very wrong noises a while back. turned out to be this:
10556446_672872982800373_289515635652979
Rebuilt the blown turbo after getting some parts :)
exhaust side after removing from the turbo. still no idea what caused it. engine has good compression. no visible damage in the cylinders. i'm at a loss to what happened.
still had some spare parts of old broken ct9 turbo's so i happened to have a spare shaft with exhaust fan
let's rebuild!
all done!
previous turbo was blue so decided this one should be red (so i can tell them apart later)
back in the car
and we power on till something else breaks on the strip
That's failed due to overspeed mate, bascially something has made the turbo work to hard, usually caused by faulty intercooler and all pipework, any boost control systems, ecu faults or faulty remaps.
been hearing that on other sites aswell.
i've been having some issues with boostcreep. getting up to 1.13 bar
think i'll fix one up and enlarge the wastegate a bit
This man is the one to listen to mate he's a turbo guru :)
James
the only thing i can think of is that it ran too much boost.
intercooler is fine, pipeworks is good. ecu is stock, map is stock. just running safc to tweak the fuel. car is running very well apart from the turbo fail
