Beastmode panda Posted November 10, 2013 Posted November 10, 2013 Did the engine swap, plugged the fan back up and when the ignition was on the fan went on straight away? :S. Engine hadn't even been run for 2 days so was dead cold. Now whenever the ignition is on the fan is on too? Any ideas guys? All I did was plug the 1 connector back in as normal. Quote
TrisK Posted November 10, 2013 Posted November 10, 2013 Wrong connector maybe. Or you might need to bridge the connections. You do on a gt but not a glanza. But :/ Quote
Beastmode panda Posted November 10, 2013 Author Posted November 10, 2013 Wrong connector maybe. Or you might need to bridge the connections.You do on a gt but not a glanza. But :/ Can't have the wrong connector man, only 1 plug on the whole car goes into the fan one lol! Same loom, same fan, same connector.. Just now it's on constantly :s. Quote
morgey Posted November 10, 2013 Posted November 10, 2013 (edited) Be an old style sensor, you need a newer one. old style they work the opposite way around. off until a connection is made (gets hot makes a circuit) break in wire you have no fan.New style is off until connection is lost (gets hot breaks the circuit) its a fail safe as if the wire breaks it cuts in and you won't risk over heating.If you car could get up to temp I bet the fan would turn off ;) Edited November 10, 2013 by morgey Quote
Beastmode panda Posted November 10, 2013 Author Posted November 10, 2013 Be an old style sensor, you need a newer one.old style they work the opposite way around.off until a connection is made (gets hot makes a circuit) break in wire you have no fan.New style is off until connection is lost (gets hot breaks the circuit) its a fail safe as if the wire breaks it cuts in and you won't risk over heating.If you car could get up to temp I bet the fan would turn off ;) Turn off? Seriously? Do I need to take a sensor off that's plugged in then? Quote
morgey Posted November 10, 2013 Posted November 10, 2013 You swapped engines right?The water temp sensor that controls the fan needs swapping from your old engine. Quote
Beastmode panda Posted November 10, 2013 Author Posted November 10, 2013 You swapped engines right?The water temp sensor that controls the fan needs swapping from your old engine. Yes, engines and box. Ergh, so long. Quote
Beastmode panda Posted November 10, 2013 Author Posted November 10, 2013 Well that would be my guess. Might just get it wired to a switch lol. Quote
morgey Posted November 10, 2013 Posted November 10, 2013 Unplug the sensor and see if it stops.then run a wire from the connector to an earth. See if it stops or starts1)If it stays running when unplugged but stops when earthed then your sensor is open when cold but needs to be closed.2) if it stops when disconnected then your sensor is closed when cold but needs to be open. Quote
Beastmode panda Posted November 10, 2013 Author Posted November 10, 2013 Unplug the sensor and see if it stops.then run a wire from the connector to an earth. See if it stops or starts1)If it stays running when unplugged but stops when earthed then your sensor is open when cold but needs to be closed.2) if it stops when disconnected then your sensor is closed when cold but needs to be open. Gotcha batman. Thank you. Quote
JDMfreak Posted November 10, 2013 Posted November 10, 2013 same thing happened to me with my glanza swap the rad fan switch for a decent one the wax or what ever is in it has broke down so basically its not working right Quote
Beastmode panda Posted November 11, 2013 Author Posted November 11, 2013 same thing happened to me with my glanza swap the rad fan switch for a decent one the wax or what ever is in it has broke down so basically its not working right Cheers mate thanks! Quote
zurgieSR Posted December 5, 2013 Posted December 5, 2013 check this also mate. http://www.toyotagtturbo.com/forums/showthread.php?92366-Fan-constantly-on&highlight=aircon+bridge Quote
Stu Posted December 5, 2013 Posted December 5, 2013 Yeah EP82 and EP91 have opposite sensor configs (normally closed vs normally open) Quote
Nilz90 Posted March 19, 2024 Posted March 19, 2024 On 11/10/2013 at 11:13 PM, morgey said: Unplug the sensor and see if it stops.  then run a wire from the connector to an earth. See if it stops or starts  1)If it stays running when unplugged but stops when earthed then your sensor is open when cold but needs to be closed.  2) if it stops when disconnected then your sensor is closed when cold but needs to be open.  I have this same issue. On my mk3 gt turbo 1994. The fan is always on constantly. Mines is 1) stays running when disconnected and when earthed it stops. is anyone able to confirm if it means I need the old type fan switch sensor or new type by this please? Quote
akyakapotter Posted March 21, 2024 Posted March 21, 2024 Has the ac been removed ? If so you need to bridge one of the connectors by the battery. Will stop the fan coming on straight away. Quote
Nilz90 Posted March 25, 2024 Posted March 25, 2024 (edited) On 3/21/2024 at 1:33 PM, akyakapotter said: Has the ac been removed ? If so you need to bridge one of the connectors by the battery. Will stop the fan coming on straight away. Managed to sort it now put an older type switch in and it worked the fan is now coming on at around 92 degrees is that correct and good for a 5E running 280bhp or would it be better to invest in a low temp thermostat? Edited March 25, 2024 by Nilz90 Quote
Nilz90 Posted March 27, 2024 Posted March 27, 2024 It stopped working the next day anyone know what can be causing it to not function again? I have voltage coming to the fan switch Quote
