Towbar Posted November 18, 2013 Posted November 18, 2013 Well mine are still fecked No dipped or high beam at all but i have side lights rear lights and front fogs,Looks like a issue with the loom running through the drivers side arch Not looking forward to it,Anyone else had any similar probs?Deff putting the inner arch back in now. Quote
turbo Grant Posted November 18, 2013 Posted November 18, 2013 I might be wrong but I thought the lights wiring ran in throw the bulk head and up to the fues box on the passenger side. Are the 2 fues ok in the fues box? Quote
TrisK Posted November 18, 2013 Posted November 18, 2013 yep it does, it runs up the passenger side from the fusebox, then crosses accross the front slam pannel Quote
akyakapotter Posted November 18, 2013 Posted November 18, 2013 Fuses are fine grant was the first thing we checked Quote
fremyjay Posted November 18, 2013 Posted November 18, 2013 Have you checked every fuse under the dash and bonnet as when my lights went it wasn't the fuse I though it would be?? Quote
Towbar Posted November 18, 2013 Author Posted November 18, 2013 I got power to the lights but only 9v?Fuses under dash and engine bay are fine,When you plug them in and switch them on nothing due to lack of voltage?Yet if you earth it out it fires up and i get 12.43v....The wiring on the drivers headlamp runs across the slam panel to the nearside then fuse box?But the loom on the drivers side also runs up inside the drivers side arch? Quote
Towbar Posted November 18, 2013 Author Posted November 18, 2013 Took them off last night cleaned them up, still no joy,Stupid ass starlets and gay electrics lol Quote
jellybaby Posted November 18, 2013 Posted November 18, 2013 check the earth wire from the fuse box to each light sound like u got a short some where use multi meter do a resistance check along the wire a bull ach I no but worth it or find the earth wire for the light from fuse box and run a new earth to each of the lights Quote
Towbar Posted November 22, 2013 Author Posted November 22, 2013 Right light problem solved Its my actual light stalk thats burnt outThe auto electrican was really good honest and quick about it,Got one sorted from a fellow ukso member ,Just hope it deffo is that Thanks for all the suggestions and advice Quote
