scutch0 Posted November 7, 2007 Posted November 7, 2007 my temperature needle has always sat at the same spot ever since ive has it, (a tiny bit below half way) i have started noticing that its dropping a bit below that at the mo just during normal driving... i suspect it might be the thermostat but i just wanted to see if anyone elses needle drops this low?this is after a hour driving! it'll go up if i boot it, but it just seems to like sitting here now! Quote
SiCaln Posted November 7, 2007 Posted November 7, 2007 mine would sit roughly between where your fuel gauge and temp gauge is now Quote
scutch0 Posted November 7, 2007 Author Posted November 7, 2007 what do we think? thermostat fooked? Quote
WallaceGlanza Posted November 7, 2007 Posted November 7, 2007 Mine is actually sitting a little below that most of the time now. It used to sit where Si suggested but I've noticed it fluctuating more recently, it will go up when driven hard as you say.I'm notreally worrying about it aslong as its not overheating. Quote
SiCaln Posted November 7, 2007 Posted November 7, 2007 i changed the coolant and thermo to a SARD one less than a year ago Quote
lobotomy Posted December 23, 2007 Posted December 23, 2007 It's 100% your thermostat Scutch... had the same problem with my Glanza, changed it for just a blueprint style one out of the motorfactors and it never budged from halfway the rest of the time I had the car. Quote
BradGTT Posted February 21, 2008 Posted February 21, 2008 my temperature needle has always sat at the same spot ever since ive has it, (a tiny bit below half way) i have started noticing that its dropping a bit below that at the mo just during normal driving... i suspect it might be the thermostat but i just wanted to see if anyone elses needle drops this low?this is after a hour driving! it'll go up if i boot it, but it just seems to like sitting here now!my needle seems to be going the same as yours i just put it down to the colder weather ? it sits just above quater way up unless i boot it or sit at a standstill then it goes up to half way.i have recently changed the coolant though ?!?!?if it is the thermostat will it do any harm if you dont change it ? Quote
WallaceGlanza Posted February 21, 2008 Posted February 21, 2008 my needle seems to be going the same as yours i just put it down to the colder weather ? it sits just above quater way up unless i boot it or sit at a standstill then it goes up to half way.i have recently changed the coolant though ?!?!?if it is the thermostat will it do any harm if you dont change it ?Well your engine won't be running at itsproper operating temperature so its better to get it changed. It only costs like 15 quid for a new thermostat and is piss easy to change. Quote
SooperD Posted September 7, 2008 Posted September 7, 2008 Mine stays just below the halfway too. But my fan comes on sometimes. Is that right ? Also the coolant is just the usual water right ? nothing fancy added etc ? Cheers.D Quote
WallaceGlanza Posted September 7, 2008 Posted September 7, 2008 Mine stays just below the halfway too. But my fan comes on sometimes. Is that right ? Also the coolant is just the usual water right ? nothing fancy added etc ? Cheers.DYeah thats normal. if you just use water it will freeze in winter, not really that good!You can get proper toyota "for life" coolant which is red or the similar stuff from halfords. Quote
starlybruiser Posted September 7, 2008 Posted September 7, 2008 yeah you should have proper coolant in there really because it has anti corrosion properties too as well as stopping it freezing in the winter Quote
Bourkey Posted September 8, 2008 Posted September 8, 2008 Mine sits perfectly half way all the time. I also have a magical coolant system. It takes all the coolant out of the liquid and just leaves water behind. Even in the bottle. Weird i know.Bourkey Quote
SooperD Posted September 10, 2008 Posted September 10, 2008 Ill invest in some of that coolant methinks. Im guessing it doesnt freeze ? Quote
StarletRick Posted September 10, 2008 Posted September 10, 2008 oh no, it does freeze, they just call it anti-freeze to mislead you. Quote
