Kingcarr Posted December 17, 2013 Posted December 17, 2013 Morning Guys, This Morning on the way to work, I was nearly at the office after taking it easy waiting for her to get up to temp. On the final stretch I decided to give it a little more, but not the bull beans, and there was a big bang, like a misfire. immediately turned the engine off as it sounded like it was running on 3 cylinders, and rolled the rest of the way to the office. Got outside work and popped open the bonnet, oil has sprayed all up the back left of the engine bay (around the alternator and brake cylinder) so I got my generic mobile mechanic friend to come and look... as there is now a pool of oil underneath it! He said the good news is there isn't a conrod or piston hanging out the back, but there is a lot of oil around the rear of the engine on the alternator side, near a sensor? He had to bugger off as he was booked out, so we are inconclusive! what could it be? Please help! cheers Nathan Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 I would have been just coming into boost @ around 3k revs... if its any use!?! Quote
daniel_g Posted December 17, 2013 Posted December 17, 2013 Stab in the dark, crank oil seal has let go ?It could literally be anything though, pics etc will give us all a better idea. Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 dipstick is still in place, im working at the moment so cant get pics! it instantly ran like shit after it went bang, sounded like something popped out but I walked up the road and didn't see anything? oil has pissed out of somewhere as the firewall, and brake cylinder are covered! it seems to be more around the area of where the knock sensor on the back of the block is? like under the inlet manifold area... Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 HG wouldn't cause the oil to piss out though would it? I literally have a puddle of oil under the car! Quote
daniel_g Posted December 17, 2013 Posted December 17, 2013 Yeah it can do, depends how bad it failed, ive seen some cars lose litres from HG failure.But as i said it could be anything really, just guessing here. Quote
Chris Green Posted December 17, 2013 Posted December 17, 2013 Dipstick tube would be a good call, check it's still in where the tube meets the block. Although it wouldn't really explain the bang. Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 or it not running right? suppose the bang could have been a backfire? but still doesn't explain... will pop out and have a wiggle at lunch Quote
Phil Posted December 17, 2013 Posted December 17, 2013 I hope not! well its just a guess. wait till you find a hole in your block before you panic Phil Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 (edited) just went out and had a look, theres a mix of oil and water, so might just be the HG? its not overheated or anything though? theres jizz in the oil cap! Edited December 17, 2013 by Kingcarr Quote
Chris_GlanzaV98 Posted December 17, 2013 Posted December 17, 2013 Perhaps the HG was on the way out and a missfire has somehow acted as a catalyst for it I would tow it home just to be safe mate Quote
Taggy Posted December 17, 2013 Posted December 17, 2013 lets pray for a HG failure, it will certainly be hell of alot cheaper! Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 im just concerned about the amount of oil that poured out when I stopped. surely that amount wouldn't have come out of a failed HG? especially as the engine was off as I rolled down the hill to a stop? half tempted to see what happens when I start it... if its a rod or piston would it turn over still or would it be a mass of metal mess? maybe remove the spark plugs and turn it over? Quote
corofin12345 Posted December 17, 2013 Posted December 17, 2013 (edited) dont turn it over.. if oil has poured out from somewhere then you have no oil pressure.. you will spin a bearing if you do.. get underneath and try and source where the oil is coming from Edited December 17, 2013 by corofin12345 Quote
Phil Posted December 17, 2013 Posted December 17, 2013 dont turn it over.. if oil has poured out from somewhere then you have to oil pressure.. you will spin a bearing if you do.. get underneath and try and source where the oil is coming from agreed. Phil Quote
Kingcarr Posted December 17, 2013 Author Posted December 17, 2013 ok, ill see if my mate can look at it as im working all week! Quote
Kingcarr Posted December 18, 2013 Author Posted December 18, 2013 I'm gonna be optimistic, if it's the head gasket, what sort of money is the parts list going to cost? Quote
yaristurbo Posted December 18, 2013 Posted December 18, 2013 Gasket set from anywhere full engine ones are about 120 and then need a cam belt kit Quote
Kingcarr Posted December 18, 2013 Author Posted December 18, 2013 headbolts too? is it worth upgrading stuff? I got told I can get the head skimmed and checked for £40, plus an additional £80 for port polishing, angling etc... worth doing? Quote
daniel_g Posted December 18, 2013 Posted December 18, 2013 Just to pre warn you, this is how the majority of the big builds come about haha, find yourself saying, 'i'll just upgrade this, and may aswell do that too etc.' Before you know it your a couple of K down and still no furter on haha. Quote
Kingcarr Posted December 18, 2013 Author Posted December 18, 2013 im considering breaking it more than anything to be honest! I did say to my mates if anything big needed doing id break it... maybe the time has come Quote
