Just took my glanza for mot and all was fine except emissions.. On all tests the CO was about 6.5 - 7% and the lambda was 0.82.... Both fails, but HC passed (just - by 4ppm!!) any thoughts would be good :) I'm thinking boost leak, or too high fuel pressure or timing?! It's got fuel pump, fpr, cat was fitted, ct9 turbo, runs a little rich on low rpm and a bit lean on high rpm..
Had a lot of stress with the car recently, and was hoping it'd go we'll for a change! Not driven the car for a month and a half! :(
Set the ignition timing to 10* BTDC
Set the fuel pressure to standard which iirc is 2.4bar (if you have an aftermarket FPR)
Check for any exhaust leaks
Check for drawing in air at inlet (this would normally give hunting / a high idle)
Replace the o2 sensor if you want
Take it for a good run, kick its cunt in and get the cat up to temp
Yeah the CO is waaaay over, normally just overfuelling but there are hundreds of causes, few to check.
Fucked o2 sensor
Restricted air filter
Vac leaks to MAP sensor (car would barely run)
Fucked cat or not up to temp
Carbon canister fuel vapour system inop
Fuel / oil contaminated together
Or just not changing oil frequently
Thermostat stuck wide open
Thats concentrating on the CO related things.
Hope this helps somewhat buddy and keep us up to date with how you get on :)
  • 4 weeks later...
Im having the same prob,have changed cat,lambda,injector seals an still the same!
Mines not as high tho both idles are in around 3.4percent..
So glad I've got a glowbadge no emission test for me just a visual smoke test !!
But say that my mate used to do emmision test on my car with his eyes closed
