As Above.
Don't get it sand blasted as the sand will get in behind the baffle and stick there.
Would acid dipping it afterwards not clear that?
Do it once take it off replace the pcv valve buy a new gasket set off ebay and bolts etc get it all looking top notch job done :)
it so, so simple to take off dude :) just pop a bit of clingfilm over your cams when its off, its what I do. done a few rocker covers myself now, and as above may aswell do the bolts too. and a new pcv/gasket of course
to do it right, you need to take the rocker back to clean aluminium, de greese, then ETCH prime the bare ali, as normal primers dont stick very well to the ali and will eventually flake off. once etched, a light sand then start applying your top coats. if you dont etch it it wont take long for the top coat paint to start flaking off. i just use normal car rattle cans when i do it.
  • 3 weeks later...
