Have been busy lately so no real time for this atm but done a couple little bits like painted the starter, the alternator the fuel rail and some mounts, also fitted wind deflectors, then today I removed the head, every cam bolt was rounded and every head bolt was rounded to from the retard before but found the issue with the lack of compression the head gasket had gone and also found some marks on 1 piston and head
Edited by Glanza-Ben
  • Replies 181
  • Created
  • Last Reply
Top Posters In This Topic
Just ordered all these from iddy at Id workz to see how this engine runs as if ok then will get another engine to forge while running this at 1bar on td04
OE Genuine - Distributor Seal O Ring
Genuine - Oil Filter Housing Gasket
Genuine - Throttle Body Gasket
OE Spec - Exhaust Manifold Gasket
OE Spec - Head Bolt Set
OE Spec - Head Gasket 4E-FTE
OE Spec - Oil Filter
Bonnet is being sorted and tried out some paint today, block is being blue as seen, the head silver and sump and rocker goin yellow with a vxr blue bay
Also found the rocker that came with the engine had a huge crack along it but been painted over
  • 2 weeks later...
Slow and steady more like lol never time to do anything atm :(
Same mate!!!
Mines all weather dependant!, :(
I just cant get the parts needed from breakers so now buying another gt to strip myself lol
  • 2 weeks later...
Specs
Brand new built engine with receipts and pictures
Wepr td04
Tial wastgate
Nrg leads
Pollybushed mounts
Civic rad and brackets
Temp sensor and gauge
Afr gauge and sensor
Oil temp sensor and gauge
Boost gauge
Oil sandwich plate
D2 coil overs
Greedy emanage ecu
Remapped at td
Leather bucket seats
Oem rear brace
Front mount
Original hks ssqv
Hks evc
Hks turbo timer
Alloys new tyres
Carpeted rear
Walbro fuel pump
Blitz nur spec r
Lsd oem box
New exedy stage 2 clutch
She looks smart from that side picture
It's decent but been slapped together and not looked after would need a strip down and all refitted if was not being stripped
Donor V looks alright. Why did you need a full car as a donor though, though you were nearly there with the GT ?
Got a complete car as was getting fed up with tryna get all little bits and bobs no breakers would sell as worth no money so deceided to buy a complete car to bring the gt back to life
put the car on a ramp at work and glad its being broke what a shed but on plus side it has polybushed rear beam don't look fitted right though
10404267_875100322514797_557853142874741
10348385_875100332514796_611237614834668
