Little bit done today, removed old air con pipes from bulk head and fed wiring for, emanage map sensor, boost controller loom, oil temp and pressure wiring and water temp wiring also removed the emanage fron the glanza ready to wire into the gt
  • Replies 181
  • Created
  • Last Reply
Top Posters In This Topic
Got up abit early today do do a couple bits, intercooler is fitted and sat behind bumper with no cutting at all, strut brace refitted, polished inlet and done a couple other bits, just need to fix radiator in place and clean a few more bits in the bay
nice gauge, saves the headache of having too many gauges in the dash, if it a bit cheaper would consider it ! good job on the build
Have 4 other gauges aswell lol just need a new boost gauge :)
And cheers it's come along way since I got it
when going to fit my gauges I realised my piller pod was 60mm luckily I found a swap for this center console which holds 3 52mm gauges so that's ideal for now
Nice build. I like the engine build but what happened? Why didn't you use it? Was it because of that damage?
Engine was sold on for extra funds this one is rebuilt aswell just needs painting which I need to sort and was easier at the time for me to lift out the motor and gearbox etc from one car and drop in the other
Edited by Glanza-Ben
Your making more progress than me Ben! I need to do a write up but just don't get on the PC often plus its to much of a state to put on here
Tomorrow should be a good day on updates, hoping to sort interior, fit the new brakes and possible rear axle swap but weather depending
Nice. Yeah makes sense. Why didn't you save the Glanza, they seem to command more money than the GT's
Why? Cause it was a piece of shit lol, wiring cut and bodged, shell rough, and bent chassis leg plus why save a glanza when I'm building a gt? Have had and stripped loads of glanzas in the past so wanted to do a gt
So jealous I should be wiring in my gauges :(
Not like its any use with the engine all stripped down.
Might try removed my window motors to see if I can repair them.
My windows did not work and found who ever stripped the shell unplugged a load of loom :/
Looks good dude!! How do you rate that AFR gauge?
It's a narrowband gauge and not really it came in the car I stripped so.just wired it in for the more gauge look lol
