I knw that there is no direct sensor for cam and crank, its all from the distributer as someone told be before. But how does the ecu get to know the right time and angle for ignition? There must be an input to the ecu from the distributor to let the ecu know all the information for the ignition timing.and i am looking for that input for wiring up the aem fic6. As it requires crank and cam sensor input for contorilng ignition.
NE
NE-
IGT
IGF
STA
In these pins may be the information i am looking for, but i am not sure.
NE (may be positive for mag type crank input)
NE- (may be negative for mag type crank input)
Not sure :-(
Can anyone clearify it would be very helpful!
I assume you are wiring in an aftermarket ecu?
There is a 24tooth wheel and a sync wheel (two syncs) inside the distributor below the rotor which tells the ecu the engine position. They are reluctor type triggers. NE is the 24tooth trigger usually TRIG#1, G2 is the sync usually TRIG#2 (Note, depends on which ecu you are wiring in), don't normally need the second sync. Looking at the distributor plug from wire side), Trig#1 is the far right, TRIG#2 is second one in from left, far left is ground to ecu SIGNAL EARTH not main earths.
IGT is the output from the ecu to trigger the ignitor (spark event output).
IGF is a feedback from the ignitor to the stock ecu to confirm there has been a spark event - if there isn't any feedback the ecu will show a fault code. This isn't usually required for aftermarket ecu's.
STA tells the ecu the engine is cranking which enriches the main injectors for cold start essentially.
Edited by Stu
Pin Name Wire Color Wire Marking Intercept/Tap
1 Fuel injector 1 input Dk Blue INJ 1 IN Intercept
2 Hall style sensor Cam 2 output Yellow CAM2 HALO + Intercept
3 Hall style sensor Cam 1 output Yellow CAM1 HALO + Intercept
4 Power GND Black PWR GND Tap
5 Signal GND Black SIG GND Tap
6 TPS input White TPS + Tap
7 Hall style sensor Crank input Green CRK HALI + Intercept
8 Mag style Crank sensor negative input Green CRK MAGI - Intercept
9 Mag style sensor Cam 2 positive output Yellow CAM2 MAGO + Intercept
10 Mag style sensor Crank negative output Green CRK MAGO - Intercept
11 Mag style sensor Cam 1 negative output Yellow CAM1 MAGO - Intercept
12 Fuel injector 2 input Dk Blue INJ 2 IN Intercept
13 Logger trigger input White LOG IN NA
14 Hall style Crank sensor output Green CRK HALO + Intercept
15 Power GND Black PWR GND Tap
16 Ignition power Red IGN PWR Tap
17 Not Used Not Used Not Used Not Used
18 Not Used Not Used Not Used Not Used
19 Mag style crank sensor positive input Green CRK MAGI + Intercept
20 Mag style Cam 2 sensor negative output Yellow CAM2 MAGO - Intercept
21 Mag style Crank sensor positive output Green CRK MAGO + Intercept
22 Mag style Cam 1 sensor positive output Yellow CAM1 MAGO + Intercept
1 Bank 2 oxygen sensor modifier Pink O22 + Tap
2 Not used Not used Not used Not Used
3 Not used Not used Not used Not Used
4 Hall style Cam 2 sensor input Yellow CAM2 HALI + Intercept
5 Mag style Cam 2 sensor positive input Yellow CAM2 MAGI + Intercept
6 Not Used Not Used Not Used Not Used
7 Mag Style Cam 2 sensor negative input Yellow CAM2 MAGI - Intercept
8 Hall style Cam 1 sensor input Yellow CAM1 HALI + Intercept
9 Mag style Cam 1 sensor positive input Yellow CAM1 MAGI + Intercept
10 Mag style Cam 1 sensor negative input Yellow CAM1 MAGI - Intercept
11 Fuel injector 5 input Dk Blue INJ 5 IN Intercept
12 Fuel injector 3 input Dk Blue INJ 3 IN Intercept
13 Banks 1 oxygen sensor modifier Pink 021 + Tap
14 MAF signal input Dk Blue MAF IN + Intercept
15 MAF signal output Black MAF OUT + Intercept
16 VTEC output White VTEC OUT Intercept
17 Fuel injector 6 output Dk Blue INJ 6 OUT Intercept
18 Fuel injector 5 output Dk Blue INJ 5 OUT Intercept
19 Fuel injector 4 output Dk Blue INJ 4 OUT Intercept
20 Fuel injector 3 output DK Blue INJ 3 OUT Intercept
21 Fuel injector 2 output Dk Blue INJ 2 OUT Intercept
22 Fuel injector 1 output Dk Blue INJ 1 OUT Intercept
23 Fuel injector 6 input Dk Blue INJ 6 IN Intercept
24 Fuel injector 4 input Dk Blue INJ 4 IN Intercept
this is my Aem fic6 22pin and 24pin connector pinouts.
as i hv come to know that our engine dont have cam sensors so i hv eliminated the cam 1 and 2 input/output wires. so only left iis crank.
as a mate here told me that 5e has magnatic style sensor same as 4e so i need 2 wires to have input to the aem fic6 + and -
i hv assumed that NE is mag input + for crank and NE- is mag input - for crank as well.(at my 4efe stock ecu pinout.pic given at the top of this page)
is my assumtion ryt?
thanx in advance
Ah, its only a plug in. Just downloaded the software and manual, clunky...
Yes use NE and NE- for crank pickup (reluctor/mag)
Use G for cam sync (reluctor/mag)
I hv wired the ecu. I hv taken ("NE" as positive for crank +) and ("NE-" as negative for crank -) and these are mag type sensors.and the connection was intercepted between the 4efe ecu and factory harness.i didnt connected any cam wires of my aftermarket ecu.
But the problem is my car won't start. It sounds like there is no spark! If the crank wires are right and as i hv not connected any cam wires(intercepted/cut) to the 4efe ecu it should start ryt? Any idea?
And as you said G is for cam, then i also need another wire to connect it with the after market ecu.positive and negative.
I'd start by continuity checking between your intercept wires and the dizzy plug, make sure they're going to the right pins.
I don't have the aem software but can you check its registering rpm when cranking?
It may need the cam sync - most aftermarket ecu's I setup do need it
Ok, here is the problem. I hv logged it with my laptop.everything is fine. But there is no fuel work!.
Checked the Ne+ and Ne-.the input goes to aem and then output from aem goes to ecu.aem dont feed output of ne- and ne+ to the ecu.thats y ecu is not injecting fuel thus car not starting.
What can be the cause? Is tha sensor not magnetic type? Or is it hall effect? Any idea?
Is the AEM not reading any input signal when cranking?
Looking at the dizzy plug (ie from wire side) with the plug latch at the top the 24tooth pick up is the far right, sync is second in from left, ecu sensor ground far left if you need it. Double check your using the right inputs.
They're not hall effect sensors
EDIT: What sort of filtering does the AEM have if any?
Edited by Stu
Another fellow starlet owner from india had the same problem wiring the aem.by reading his thread i hv come to know that he was facing the problem because of connecting the cam input wrong.when he corrected it he managed the car to startup.i followed his wiring and checked my wiring for crank positive and negative which was fine.then i wired the cam negative input/output as he wired.but for cam positive there is no input in my ecu.it is named as G1 in his 4efte ecu pin num 8.but in my 4efe ecu the pin is blank(in my ecu all the connection is same as 4efte except few).
From where i can get the cam positive input?
Here is my ecu pinout
Connector A
1) IPV
2) NSW (neutral start switch)
3) THW (water temp)
4) PIN (vacuum sensor)
5) THA (intake air temp)
6) IGT (ignitor)
7) IGF (ignitor)
8)
9) NE- (distributor)
10) OX (O2 sensor)
11) STA (cranking)
12) #10 (injector)
13) E01 (earth)
14) DISC (idle control valve)
15)
16) E2 (output voltage to senssors)
17) PSW (tps)
18) VC (vacuum sensor)
19) IDL (tps)
20) SEL (for air con econ/auto)
21) NE (distributor)
22)E21
23)
24) E1 (earth)
25) #20 (injector)
26) E02 (earth)
Connector B
1) +B1 (through EFI relay)
2) BATT (from IG1 key position)
3) CCO (from exhaust temp switch)
4) FC (fuel pump relay closed)
5) ELS1 (lights on)
6) AC2 (a/c on)
7) TE2 (to check connector)
8) TE1 (to check connector)
9) +B (through EFI relay)
10) W (check engine light)
11) EGW (exhaust temp warning light)
12) AC1 (air con on economy)
13) SPD (from speed sensor)
14) ACT (to a/c)
15) ELS2 (rear demister on)
16) VF (to check connector)
Thanx in advance!
  • 7 years later...
Hey guys.  Where does AC2 go from the ECU pinout? I’m adapting the Corolla loom to the fte ECU and the last elements to match are AC2 (that isn’t on the 4efe pinout. The Corolla 4efe ECU has only AC1.
Can you help?
@Claymore
Edited by Frankieflowers
On 9/30/2014 at 6:18 AM, Adeeb1395 said:
NE (distributor
@Claymore
The situation is quite interesting. So to recap I have a Starlet for EFTEEP 91 engine with air-conditioning and obviously ECU in a Corolla E11 4efe with electronic and coil ignition. To make the Starlet AC work I need  NE and NE- signal that originally was going from the 4efe Corolla ECU from pin 1 to IGN pinout 4 on the AC computer. This signal he’s needed to have the RPM levels in order to permit the computer to switch the air conditioning on and off after engineer condition and to limit it’s work on high rpm. This system on the Starlet works differently because the computer is different. The principle is the same tho. The air conditioning computer needs a RPM signal to regulate its functioning.
The easiest way to solve this would be to get the Starlet ecu NE signal but I am not sure if it is possible to split this signal that could possibly create interferences to its original function. We are creating a custom, and adoption that needs to be tested but I want to be sure I don’t fuck up. With someone be able to help me understand if I can use the NE signal or is it another signal I can pick to give the air conditioner and computer and RPM signal?
