Andy32 Posted December 8, 2014 Posted December 8, 2014 Hi looking for some advise again guys.Looking to decat the GT and wondered is it a straight forward job, as in does it need anything readjusting such as fuelling etc or is it a bolt on and forget??Also does standard lambda in decat work ok??Many thanks again for any advise!!Andrew. Quote
Ollieh17 Posted December 8, 2014 Posted December 8, 2014 Just bolt on mate, standard lambda will fit in the thread. From my experience doesn't bring a engine managmemet light up either. There is two 'lambdas in the standard cat' one is a cat temp sensor. You can unplug this with a decat Quote
glanzadude Posted December 8, 2014 Posted December 8, 2014 Yes mate just fit and forget till mot Quote
fiddlersport Posted December 8, 2014 Posted December 8, 2014 will be doing mine soon, just the advice i needed, top notch Quote
crawleysam Posted December 8, 2014 Posted December 8, 2014 If it's pre 92' you'll pass with decat iirc Quote
5e colin Posted December 8, 2014 Posted December 8, 2014 a great upgrade to go with it is a light fly does wonders for rising revs :) kinda free bhp Quote
daniel_g Posted December 8, 2014 Posted December 8, 2014 Can go right up to 31.7.1995 and still pass emissions with a decat, aslong as the engine is sound, not buring oil or that. Quote
Glanza-Ben Posted December 8, 2014 Posted December 8, 2014 Easy mod takes around 30 mins to swap it over Quote
Ollieh17 Posted December 8, 2014 Posted December 8, 2014 Not essential but alot easier if you take the rad out first Quote
fiddlersport Posted December 8, 2014 Posted December 8, 2014 less risk of damaging the rad that is if you have the stock but most people are running the civic rad, half the size Quote
Ollieh17 Posted December 8, 2014 Posted December 8, 2014 Chances are, if itsstill got the cat its still got a standard rad! That was my assumption anyway.either way, no rad alot more space Quote
mikey4410 Posted December 8, 2014 Posted December 8, 2014 will very possibly overboost with a decat though so be careful. u dont wana keep hitting fuel cut. Quote
Ryan_EP82 GT Posted December 8, 2014 Posted December 8, 2014 Makes a nice change to the exhaust note too Quote
Gainzy Posted December 9, 2014 Posted December 9, 2014 Look for a blitz cast iron decat and be prepared to buy new genuine gaskets x2 Quote
Andy32 Posted December 9, 2014 Author Posted December 9, 2014 thanks for the input guys much appreciated,going off the subject a little but is the only benefit of a half rad to help with fitting different turbo?And yeah at mo she pretty stock engine wise! Quote
Ollieh17 Posted December 9, 2014 Posted December 9, 2014 thanks for the input guys much appreciated,going off the subject a little but is the only benefit of a half rad to help with fitting different turbo?And yeah at mo she pretty stock engine wise!Pretty much, stock radiator is fine! Quote
Ryan_EP82 GT Posted December 11, 2014 Posted December 11, 2014 Ive a genuine toyota steel turbo to decat gasket if ya want it Quote
