Hi looking for some advise again guys.
Looking to decat the GT and wondered is it a straight forward job, as in does it need anything readjusting such as fuelling etc or is it a bolt on and forget??Also does standard lambda in decat work ok??
Many thanks again for any advise!!
Andrew.
Just bolt on mate, standard lambda will fit in the thread. From my experience doesn't bring a engine managmemet light up either. There is two 'lambdas in the standard cat' one is a cat temp sensor. You can unplug this with a decat
thanks for the input guys much appreciated,going off the subject a little but is the only benefit of a half rad to help with fitting different turbo?And yeah at mo she pretty stock engine wise!
Pretty much, stock radiator is fine!
