  • Replies 140
  • Created
  • Last Reply
Top Posters In This Topic
Cheers!
Your car looks cool by the way, lots of nice details! I have the same catch can as you but I have problems fitting it up because my dump valve points straight towards to it and it's on the way. I have ordered a 90 degree silicon joint if I could clear it with that...
  • 2 weeks later...
been a while since i updated this
nothing to exciting has gone own but got to the bottom of a pain stakingly stupid abs issue which i think the two front abs sensors were causing the hassle
picked up a few little bits blue battery clamp , moman dials, clear cam cover and a varis front bumper picked up a lot of silly parts just to finish it off and get it ready for test have to get a windscreen a drivers side mirror and car tracked and should be test ready new polybush exhaust hanger bushes fitted also had rocker coversmoothened and polished probably done a few other bits since
then its off for paint again ha going to get a 98 spec uncut bumper or tidy cut one and have the livesports lip fitted to that as i can run that bumper and lip with s bonnet and varis front bumper and bonnet either (nice to have choice :D )
completly put the inside of the carback together and brought the car for its first proper long drive last night and all temperatures seem spot on been a while since i drove one and my god have i missed it there great little cars even with standard ct9 on it ha also welded a crack in my manifold still no sign of my wepr one :(
anyone know for certain if all glanzas came with electronic air bags?? i have no airbag ecu or airbag wiring on loom? but could have been removed by previous owner? have stumbled across and old post by corofin saying some of the early 97 glanzs had the mechanical bag? i have fitted a mechanical bag and have never had a light on on the dash think i might just chance it for test
few pics as always ha
  • 2 weeks later...
little update got my hands on my new hella horns and i think they look the business yellow outer ring with inner blue ring work in perfect with the car an the bay and just look mean behind the bumper (if it wasnt butchered icon_bounce.gif ) will get a few better pics the weekend in light
got a new windscreen and need to collect a few more silly bits for test
but gor good news the weekend as my wepr kit is complete so hopefully will be with me soon need to get my hands on a wastegate and tubby and get ready for new headaches icon_biggrin.png
received_940564409384449_zpshhid6ta2.jpe
received_940564406051116_zps4hwinow0.jpe
She has nct/mot the 8th of April if that goes well she's going for paint to get the kit fitted then she will be road worthy ha for the summer an all going well will be time to chase more power ha
Ha thanks man.. loud but that was just a quick test off the battery so I was fairly stuck to then will get them wired up the weekend an see what there like
  • 3 weeks later...
so update at last ha wepr manifold has arrived an its utter porn :cheers: :cheers:
bought a new tial wastegate off tuning developments in blue of course
got a 1 way valve for breather off fuel tank
replaced my top mounts due to a rock in them
handbrake cables replaced and a few other bits that have seen a good few late nights the last week to have it ready for test tonight
sadly it failed emissions on high idle 0.63 shouldnt be over 0.30 perfect on low idle , lambda and ppm thinking exhaust leek but cant see really where as exhaust is mint an well sealed but only thinking when i got home is the spark plugs have never been changed so that might be the problem??
also need to get an engineers report for the front and rear arb and brackets holding on front calipers
other then that she was spot on even on the airbag situation :cheers:
slightly raging that i wont get to fit manifold set up just yet :(
got a bit carried away with pictures ha
  • 4 weeks later...
