Hi,
​Well picked up the cylinder head today and its full of swarfe. So what's the best way to clean it without damaging the stem seals or corroding parts.
​I was thinking, I know this may be bad, put the item in a box. Pressure wash the exterior and interior avoid direct pressure to the springs.
​Then quickly empty and finish cleaning with petrol.
​Then dry and coat in oil, WD etc.
​What do people think?>
I would just say use petrol tbh but i could well be wrong,
you could take it to a machinist and I think they dip them in containers?
Ive pressure washed heads before, although i had totally stripped them down (collets, valves, springs, stem seals etc.)
Also best to do the stem seals whilst you have a chance, only 30 quid or so. Plus they will do doubt get damaged with any attempt to clean the head.
FML! WILL I EVER GET THIS DONE!
But thank you for saying this. You're right, I know you're right. And I was thinking about it on the way home. I want to do a proper job. I'll rebuild the head.
Next question, what exactly will I want to replace. Stem seals and springs? Just the stem seals.
Also how do completely dissemble the head?
I really didn't want to do this, but I can only see it destroying my cylinder if I don't.
Good news though for anyone who cares, the head was badly warped, but it wasn't cracked. So that's always something.
Advice appreciated.
Just the stem seals. All you need is some spring compressors, pretty easy but fiddly job. The valves are a bugger to clean too.
Best to blow the head out with an airline ideally, if you have access to one, to make sure all the water galleries are clear.
Just make sure you dont loose any collets lol, pretty fiddly to do, use a small flathead screwdriver with a bit of LM grease to put them back in. Valves can be cleaned well with a rotating buff. And if you are carefull you can put the stem seals back in with simething like a 14mm socket.
Also advisable to get the head skimmed and checked by a machine shop
Lol. I didn't know what the collets were. Binned them! LMAO. Oh dear....
But yeah heads already skimmed and good to go. Hence why it needed cleaning. But now I've been told best to lap the valve and valve seats. So that's another job for another day :( Literally this car is never going back together at this pace.
I managed to get most of the collets but need to buy about ten or so. Why can't they just be a standard size!
you can put a lot of hour's into a head, i spent 7 hours taking valves out cleaning them, replacing stem seal's and grinding valves back in.
kevin
Sounds about right, start to port, polish etc your talking 30-40 hours.
do this lol
alloy cleaner soap and a power hose VIDEO LINK BELOW
http://vid710.photobucket.com/albums/ww102/gtadvance09/2014-01/2DEADC69-BB81-46BA-8C72-B92F54F59B4F_3.mp4
quick skim at the local shop
strip head
72E55CE9-ED81-4F50-A7F9-C4AC68666706_1.j
new stem seal
1E370E1C-2C90-4D15-A713-A9554B307E91_1.j
new exhaust valves
6417FE67-F289-449B-B38B-D6FE34CC9AD8_1.j
polished intake valves
Lap them all in and number them up.
start reassembly
valves/springs/stem seals/retainers/collets
half way
Finished :)
and onto the block
Phil
Edited by Phil
Aww that's lush! Would love to have the patience for that!
couple of evenings had it sorted. tedious in parts lol
How close to done is your Phil what's the spec looking like?
its nearly there.
spec is
Wiseco forged pistons
Scat Forged Rods
Polished crank with over sized mains
ACL mains KING big end bearings.
Athena HG 1.2mm
Speedvision Billet Cams 265degree
Blitz flywheel
just waiting on Chris to get time to swap the cam gears over and fit/shim
then it'll be full steam ahead
Phil
Edited by Phil
