turbominicooper Posted March 18, 2015 Posted March 18, 2015 so im making a budget JAM manifold and have been grinding out the middle. would people say this is enough or keep going until its totally flat? Quote
ste91 Posted March 18, 2015 Posted March 18, 2015 Looks like all you've done there is removed the divider which if anythng will have made it worse, the idea of porting the standard manifold is to remove the restrictions in the runners. Quote
5e colin Posted March 18, 2015 Posted March 18, 2015 now turn that bich over on her knees and look in hole nr 2 and 3 ha ha there is in both runners 2 lumps that need grinding down 1/2 lump in nr2 and a big massive lump in nr 3 !!!! Quote
turbominicooper Posted March 18, 2015 Author Posted March 18, 2015 Looks like all you've done there is removed the divider which if anythng will have made it worse really, my stainless one has no restrictions now turn that bich over on her knees and look in hole nr 2 and 3 ha ha there is in both runners 2 lumps that need grinding down 1/2 lump in nr2 and a big massive lump in nr 3 !!!! i will get on it chief. cheers Quote
_shaun_ Posted March 18, 2015 Posted March 18, 2015 aye the restrictions are in the ports them self the collector really gives no issues at all. ive never done it myself but from what i understand its a tedious job Quote
Ryan_EP82 GT Posted March 18, 2015 Posted March 18, 2015 Stock up on grinding stones..pain in the hole but obviously worth it Quote
akyakapotter Posted March 18, 2015 Posted March 18, 2015 (edited) That what you want to see thats my jam mani I have sat in my shed Edited March 18, 2015 by akyakapotter Quote
mikey4410 Posted March 18, 2015 Posted March 18, 2015 yeah what u have done there is ruin the + piece of the mani.that causes nothing but wicked flow to the turbo and aid spool.the bit you needed to do is the restriction in the third port. Quote
Gainzy Posted March 18, 2015 Posted March 18, 2015 No matter how much you port it the JAM mani's ports are bigger to start with. Quote
Matt1878 Posted March 19, 2015 Posted March 19, 2015 I would just buy Akyakapotter's jam manifold off him and put the grinder down.. Really you shouldn't have touched that side of the manifold. The restrictions are on the other side.You will never be able to getnthe stock manifold half as good as the JAM one without spending one hell of a long time doing so.... Make him an offer ;) Quote
5e colin Posted March 19, 2015 Posted March 19, 2015 turbominicooper dont worry about the + its gone and opened up the hole wish is better less restriction ( look at any other aftermarket mani they dont have it flush either ) its just on smaaal shitty ct9s wont make much diference dont worry about all that flow crap the turbo just sucks it out Quote
turbominicooper Posted March 19, 2015 Author Posted March 19, 2015 gggrrrr honestly thought the + was the restriction - what a noob. ill revisit the ports and see what its like after. Quote
ste91 Posted March 19, 2015 Posted March 19, 2015 turbominicooper dont worry about the + its gone and opened up the hole wish is better less restriction ( look at any other aftermarket mani they dont have it flush either ) its just on smaaal shitty ct9s wont make much diference dont worry about all that flow crap the turbo just sucks it out The divider is not a restriction at all, it is there to separate exhaust pulses and does actually help. Quote
5e colin Posted March 19, 2015 Posted March 19, 2015 (edited) sure it is !!! the 4 , 1/4 holes on the + are more restrictive then the loube in nr 3 runner i can barely stick my pink in there ( stock unported )i got more performance out of it be deleting the + thats for sure Edited March 19, 2015 by 5e colin Quote
turbominicooper Posted March 19, 2015 Author Posted March 19, 2015 sure it is !!! the 4 , 1/4 holes on the + are more restrictive then the loube in nr 3 runner i can barely stick my pink in there ( stock unported ) i got more performance out of it be deleting the + thats for sure this was my thinking to, less restrictions = better flow = less heat congestion = better cooling = better turbo life/performance. theres only one way to tell I suppose - dyno the same car with one mani ported and de+ and the other ported but with the + intact. bit of a giveaway how much stress is on it given the amount of cracks found in the + on your average starlet Quote
ste91 Posted March 19, 2015 Posted March 19, 2015 this was my thinking to, less restrictions = better flow = less heat congestion = better cooling = better turbo life/performance. theres only one way to tell I suppose - dyno the same car with one mani ported and de+ and the other ported but with the + intact. bit of a giveaway how much stress is on it given the amount of cracks found in the + on your average starlet The divider is not the restriction though, the restriction is in the runners, the divider is there to keep exhaust pulses separate until they reach the turbine housing, removing it is likely to cause more restriction than without it. And you are wrong about "heat congestion" whatever that is, you want to keep the exhaust gas hot (to a certain extent) as hot gas moves faster. Quote
5e colin Posted March 19, 2015 Posted March 19, 2015 the ass dyno never lies it works ha ha ^^^^^ you do know that because the restrikted + the cracks apear over time and they al start on the + because of the + extra heat is there that is not needed Quote
