Ollieh17 Posted April 1, 2015 Share Posted April 1, 2015 I was under the impression when removing the old bushes to cut out the rubber and metal inserts. However this leaves the powerflex bush loose... Quote Link to post Share on other sites
JamesD89 Posted April 1, 2015 Share Posted April 1, 2015 Think there are 2 different sizes mate, mine were tight as after fitting Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 These came off a glanza so thought theyd be fine Quote Link to post Share on other sites
5e colin Posted April 1, 2015 Share Posted April 1, 2015 the metal sleeve needs to be kept mate its a cunt of a job to get al the ruber out of the bush your fucked now you need to buy 2 new sleeves/bushes or get machine shop to make 2 sleeves Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 I was told on here to cut the whole lot out lol. Yeh pretty fucked now Quote Link to post Share on other sites
WallaceGlanza Posted April 1, 2015 Share Posted April 1, 2015 (edited) On 4/1/2015 at 1:41 PM, Ollieh17 said: I was told on here to cut the whole lot out lol. Yeh pretty fucked now Don't believe everything you read online!!! Edited April 1, 2015 by WallaceGlanza Quote Link to post Share on other sites
Idrees Posted April 1, 2015 Share Posted April 1, 2015 Instructions are included with the bushes which state to remove the bush only, and not the sleeve. Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 Problem with being cheap and buying second hand Quote Link to post Share on other sites
Idrees Posted April 1, 2015 Share Posted April 1, 2015 We've all been there at some point mate. It might be easier and cheaper to buy a UK spec axle and start again, as I'm sure you've removed your ABS anyway? Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 Wallaceglanza is gonna cut the ends of the trailing arm off and send me them. I can then get the sleeves pressd out and hopefully pressed into my axle. Then a bit of weld to hold them in place Quote Link to post Share on other sites
Calum122 Posted April 1, 2015 Share Posted April 1, 2015 Annoying Ollie, But a lesson for me at least. Sucks I Know, Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 On 4/1/2015 at 6:26 PM, Calum122 said: Annoying Ollie, But a lesson for me at least. Sucks I Know,Think a gt is different bud Quote Link to post Share on other sites
Calum122 Posted April 1, 2015 Share Posted April 1, 2015 No, but reading more into stuff rather than just hacking away, which is what I usually do :\ Quote Link to post Share on other sites
5e colin Posted April 1, 2015 Share Posted April 1, 2015 On 4/1/2015 at 6:34 PM, Ollieh17 said: Think a gt is different bud ya gt sleeve/insert is welded to the axel that cant be moved on a glanza the sleeve of the bush is pressed leaving u with fuck al Quote Link to post Share on other sites
daniel_g Posted April 1, 2015 Share Posted April 1, 2015 On 4/1/2015 at 1:41 PM, Ollieh17 said: I was told on here to cut the whole lot out lol. Yeh pretty fucked nowWho the hell told ya that! Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 Mikey... Shoulda listened to the other guy, its my fault Quote Link to post Share on other sites
daniel_g Posted April 1, 2015 Share Posted April 1, 2015 Well at least Wallace is sorting ya out Quote Link to post Share on other sites
Ollieh17 Posted April 1, 2015 Author Share Posted April 1, 2015 On 4/1/2015 at 9:30 PM, daniel_g said: Well at least Wallace is sorting ya out Yeh man top lad Quote Link to post Share on other sites
Gainzy Posted April 8, 2015 Share Posted April 8, 2015 Glad I read this be doing mine at some point to, blow torch galore! Quote Link to post Share on other sites
