dan106 Posted July 4, 2015 Share Posted July 4, 2015 Noticed today that the engine in my gt has a tick/tap that gets faster with revs etc. Now i thought this was just noisy injectors because i only ever heard it on idle, but today whilst driving past a load of parked cars i noticed its always there.So now im wondering if its the tappets, how easy are they to do/adjust? That and i found a snapped cam cover bolt today when i pulled my intercooler off, so ill have to try sort that out i spose while its off! Any help is apreciated, unless someone wants to do it for me and ill pay them ahaha Quote Link to post Share on other sites
Socks Posted July 4, 2015 Share Posted July 4, 2015 Just a quick thin,g try disconnecting your Idle control valve, see if it stops... These can make a ticking sound when there goosed! Quote Link to post Share on other sites
dan106 Posted July 5, 2015 Author Share Posted July 5, 2015 That's the one on the throttle body? I do think itll just be the rappers needing adjusting, I've never done tappers before though Quote Link to post Share on other sites
Socks Posted July 5, 2015 Share Posted July 5, 2015 No. Left of inlet on the end. Earths run to one of its mounting bolts. Worth a try. To see. Quote Link to post Share on other sites
dan106 Posted July 5, 2015 Author Share Posted July 5, 2015 Ah yeah I did unplug that one, made no difference Quote Link to post Share on other sites
Phil Posted July 5, 2015 Share Posted July 5, 2015 retension cam gear Phil Quote Link to post Share on other sites
5e colin Posted July 5, 2015 Share Posted July 5, 2015 by sound of it u never done it so not a first diy jobby affaik u need the proper measuring tools to to measure the new shims make sure to get a mechanic friend to guide/help you Quote Link to post Share on other sites
dan106 Posted July 5, 2015 Author Share Posted July 5, 2015 On 7/5/2015 at 2:15 PM, Phil said: retension cam gear Phil That sounds expensive aha, is that the pre load gear on the camshafts? On 7/5/2015 at 2:41 PM, 5e colin said: by sound of it u never done it so not a first diy jobby affaik u need the proper measuring tools to to measure the new shims make sure to get a mechanic friend to guide/help you I know you need the feeler gauges and that, i was a mechanic a few years ago, the confidence to pull stuff apart has faded a bit these days, not so much suspesion and bits like that, but im a bit nervous about making or breaking my engine nowadays aha! Ill have to see if anyone i know is up for doing it lol Also, where would i get a replacement cam cover bolt/nut, ive had a 3sgte in bits before but i cant quite remember how theyre held in? Quote Link to post Share on other sites
Johnboy GT Posted September 30, 2015 Share Posted September 30, 2015 To dig up this thread. Did you ever find out what the ticking was mate? I've checked my pre tension and my valve clearances but I've still got the same ticking that increases with revs. CheersJohn Quote Link to post Share on other sites
dan106 Posted October 1, 2015 Author Share Posted October 1, 2015 Na still does it, haven't actually done anything with it yet, it's a 170k engine after all I'm not surprised it taps slightly Quote Link to post Share on other sites
5T4R7ET N/A Posted October 1, 2015 Share Posted October 1, 2015 Manifold gasket or its cracked? I know this can cause a ticking noise Quote Link to post Share on other sites
dan106 Posted October 1, 2015 Author Share Posted October 1, 2015 Actually that reminds me, it was really bad before because the downpipes nuts had come Loose and it was blowing, stuck some nylocks on it and it went back to the normal ticking, which I've never got rid of Quote Link to post Share on other sites
StuDoc 72 Posted October 1, 2015 Share Posted October 1, 2015 Im yet to see a starlet that doesn't tick Quote Link to post Share on other sites
Johnboy GT Posted October 1, 2015 Share Posted October 1, 2015 It's just because it's a newly built engine and I can't remember it ever doing it before it was rebuilt. Granted that was a long time. Just worried is all. Maybe it's meant to be like that.John Quote Link to post Share on other sites
StuDoc 72 Posted October 1, 2015 Share Posted October 1, 2015 If it was rebuilt did you check that they did re-tension the cam? Quote Link to post Share on other sites
Johnboy GT Posted October 1, 2015 Share Posted October 1, 2015 Yeah buddy checked that, which hadn't been done but I did it last night and the noise is still there. I should really get gold of a local boy with a forged engine to see if it sounds similar.John Quote Link to post Share on other sites
StuDoc 72 Posted October 1, 2015 Share Posted October 1, 2015 Have you tried you idle control valve? Like I said mate I think they are all ticky I know mine is. I wouldnt lose sleep over it. Quote Link to post Share on other sites
Johnboy GT Posted October 1, 2015 Share Posted October 1, 2015 Going to try the idle control valve tonight just to rule it out. The tick increases with revs so I hadn't Tried it yet. Yeah I'm probably being paranoid.Cheers buddyJohn Quote Link to post Share on other sites
dan106 Posted November 13, 2015 Author Share Posted November 13, 2015 Well my major tick was actually the idle control valve, after you unplug it you can still hear the injectors Quote Link to post Share on other sites
msg1 Posted December 29, 2015 Share Posted December 29, 2015 I have this same problem, the noise started right after my forged rebuild. I picked up the car from the mechanic and there was that noise. He claimed to adjust the tappets/shims since, but same old noise...plz post a pic of this valve. I'll try this next. Quote Link to post Share on other sites
msg1 Posted December 29, 2015 Share Posted December 29, 2015 Where exactly is this valve????? Quote Link to post Share on other sites
msg1 Posted December 29, 2015 Share Posted December 29, 2015 And exactly when do I unplug it and for how long? Is it before I start the engine or while idling and for how long? Quote Link to post Share on other sites
maerijn Posted December 29, 2015 Share Posted December 29, 2015 >https://www.youtube.com/watch?v=-eOJyxiZzEc Quote Link to post Share on other sites
msg1 Posted December 30, 2015 Share Posted December 30, 2015 On 11/13/2015 at 12:47 PM, dan106 said: Well my major tick was actually the idle control valve, after you unplug it you can still hear the injectorsAnd what do you do after unplugging? Just clean and put back? Quote Link to post Share on other sites
msg1 Posted January 5, 2016 Share Posted January 5, 2016 Well I just cleaned my idle valve, could have sworn the noise was greatly reduced after running the valve back together. Switched off the engine then restarted and the noise was back to the same old, sigh... Quote Link to post Share on other sites
