  • Replies 109
  • Created
  • Last Reply
Top Posters In This Topic
I one day plan to have the parts on my car as clean as yours! It's beautiful!
Quick question are all the gold parts the same gold? If so what gold is it as the arb looks almost perfect to the gold I'm looking for
Arb is hammerite smooth gold.
Rest are a different gold.
Trick is to use zinc primer with a decent light base coat.
Cheers though fella its taking time to make everything clean.
Thanks for that! :D I'll try find a colour that is a close match, and again thinks for the advice with the zinc primer! I need to get my underside freshened up as its been an advisory to get it undersealed and the rear is starting to look a bit worn out!
Look forward to seeing the final product bud
  • 1 month later...
With christmas and new year and be being quite ill since the turn of the year.
Progress has been slow..
However i have now fitted my longer wheel studs, so hubs can go on when get some free time.
Also rear brakes and handbrake are all connected.
So rear end is built up..
Russ78 done me a nice deal as he is breaking his 1a0 glanza.
So i got the bits i was missing after the accident on last shell..
Latest pics of rear..
plan now is to bolt front end all up.
And bleed brakes to check for leaks with the new lines ive made..
So had a day off yesterday, very rare..
So decided to pop down the unit as my ball joints arrived.
So set about fitting those.
Then i realised i had my new braided lines from wms.
So decided whilst in the zone to fir my front brakes too.
Thanks fella..
Today had an unexpected call which turned out to be good news.
pro alloy who made my rad and intercooler had the founder pass away over xmas so repairing the intercooler and rad wasnt expected till march.. however they started and finished them this week.
Pro alloy made me a new radiator, but fitted a spal fan and proper brackets for nothing as old rad couldnt be repaired.
Also the intercooler was repaired at same time and pressure tested to 40psi under water and no leaks.
Heres pictures..
Also me and russ78 have made a start repairing the fibreglass panels damaged in crash. Livesports splitter is back in 1 piece.
Thanks will..
if im reshelling it had to be clean only regret it further down the line
You still breaking yours?
No mate selling It whole, might be gone Saturday :(
