SOLVED! Multiple random breakdowns..weak/no spark
What would be a sure fire way to check the pins on the temp sensor plug? I just removed it and tugged at the wires, they seems to be quite stable in the plug and the inside of the plug wasn't burned out or anything
EML won't turn on with ignition! Any ideas here? I can't even run a diagnostic!
It was turning on with ignition in previous weeks and then switching off once car was started up
  • Replies 92
F*** me, found it lol.
You guys are gonna bend me over for this but :lol:
I was checking some of the other fuses mentioned in that TGTT thread, came to the EFI one last. Prodded the wires running around the outside and one was loose, surely this was it? Poked it back in place, lo and behold the car fired up at once!
Major thanks to everyone that helped, I really really appreciate it! Just relieved it was a simple fix, albeit as long as it took! Phew!
  Quote
Posted 03 November 2015 - 04:47 PM
any fault codes?
check the earth on the manifold by the idle valve.... wire bush both surfaces then refit.
coolant temp sensor is a cheap replacment id try that next
had a similar issue on my mx5 few years ago and that was the efi relay
hate to say it but .... :p
glad its sorted dude
Edited by goldenvtr
