Amjad Posted January 7, 2016 Author Posted January 7, 2016 What would be a sure fire way to check the pins on the temp sensor plug? I just removed it and tugged at the wires, they seems to be quite stable in the plug and the inside of the plug wasn't burned out or anything EML won't turn on with ignition! Any ideas here? I can't even run a diagnostic!It was turning on with ignition in previous weeks and then switching off once car was started up Quote
funny onion Posted January 7, 2016 Posted January 7, 2016 I had no EML when i built the red one, was down to the ecu earth that's on the icv, check that Quote
Amjad Posted January 7, 2016 Author Posted January 7, 2016 Yeah we cleaned that up the other day to no avail Just found this! Might be the same fault? http://www.toyotagtturbo.com/forums/showthread.php?98332-Glanza-Not-Starting../page2 Quote
H_D Posted January 7, 2016 Posted January 7, 2016 check ignition wires under the steering column Quote
Amjad Posted January 7, 2016 Author Posted January 7, 2016 Looks okay there, fiddled around and nothing was loose as far as I could tell Quote
Amjad Posted January 7, 2016 Author Posted January 7, 2016 F*** me, found it lol. You guys are gonna bend me over for this but I was checking some of the other fuses mentioned in that TGTT thread, came to the EFI one last. Prodded the wires running around the outside and one was loose, surely this was it? Poked it back in place, lo and behold the car fired up at once! Major thanks to everyone that helped, I really really appreciate it! Just relieved it was a simple fix, albeit as long as it took! Phew! Quote
morgey Posted January 7, 2016 Posted January 7, 2016 So was the main Efi relay in the end? Lol Glad you found it dude Quote
5e colin Posted January 7, 2016 Posted January 7, 2016 yay great mate now keep the wepr kit that you have for sale and go td/vf/tf Quote
5T4R7ET N/A Posted January 7, 2016 Posted January 7, 2016 its a great feeling when you find the problem,Well done and happy boosting Quote
goldenvtr Posted January 14, 2016 Posted January 14, 2016 (edited) F*** me, found it lol. You guys are gonna bend me over for this but I was checking some of the other fuses mentioned in that TGTT thread, came to the EFI one last. Prodded the wires running around the outside and one was loose, surely this was it? Poked it back in place, lo and behold the car fired up at once! Major thanks to everyone that helped, I really really appreciate it! Just relieved it was a simple fix, albeit as long as it took! Phew! Posted 03 November 2015 - 04:47 PM any fault codes? check the earth on the manifold by the idle valve.... wire bush both surfaces then refit. coolant temp sensor is a cheap replacment id try that next had a similar issue on my mx5 few years ago and that was the efi relay hate to say it but .... glad its sorted dude Edited January 14, 2016 by goldenvtr Quote
Amjad Posted January 14, 2016 Author Posted January 14, 2016 Typical eh! Thanks everyone, new relay and it's back to its former self Quote
MustakimQZ Posted January 15, 2016 Posted January 15, 2016 Followed this with interest. Glad you sorted it out. Quote
Flaminsam Posted January 15, 2016 Posted January 15, 2016 All that for a dodgy relay! Glad your up and running again 👍🏻 Quote
