im thinking its got to be the bearings so could do with clarification:
https://www.youtube.com/watch?v=Rmn1WI4cQpU
history is:
built this motor fresh and havent even driven it yet.
used ACL bearings
plastigauged them -
put motor together using torque spec.
however... i had shit loads of auto gearbox problems so ive had the box on and off about 20 times, starting it each time.
like ive said above havent actually driven it yet so its just idled which i know isnt good but couldnt be helped.
cheers
Edited by turbominicooper
  • Replies 82
sounds lovely "!!!
use a long screw driver and fit down sparkplug hole keep your hand on screwdriver go to tdc on each cylinder and move back and forth you can feel play if there is bearing damage !!!
just lets hope you fucked up on the auto clutch side of things but i doubt it
didnt you have problems with this being to tight on the crank a while back ????? if it was for sure bearing is ground to bits by now
worst sound ever lol
dont think ive got a screwdriver that long tbh, is it easier just to whip the sump off and have a wiggle form underneath? im pretty sure it is the bearings and yuh like you mentioned i did have that issue where they were really tight.
dont think its the auto as the car moves easily enough.
sounds very like your tappy sound could be wrong though
https://www.youtube.com/watch?feature=player_detailpage&v=kQbILvqiUqw
Edited by JDMfreak
are you thinking its not the bottom end?
saying that I haven't seen the engine management light on but thinking either way im gonna take the sump off and have a good look.
checked plugs yesterday and all were of a healthy color
I seen a cam cap brake before and make that sound well similar to the noise but for peace of mind drop the sump off and have a feel of the rods for any play in them
Depends how bad shell bearings are if there severely worn then crank out will be needed and either replaced or reground
You could go replace the shell bearings and same could happen again in a matter of seconds
As you haven't ran anywhere then it's a possibility. Mine was too far gone and I had to replace engine or go down the rebuild route. Charlotte (Funny Onion) had the same problem but luckily it was just a case or replacing the bearing.
is there a possible scenario here where I can just replace the bearing (if that's the problem) without having to get the crank reground etc...
no you cant refit chels if it knocks it neads regrind otherwise the will fail to
its not a light knock there thats really hard already damage is done
Yeah when the bottom end went on my Advance i managed to just wet and dry the crank with very fine (2000-3000grit sandpaper) and fit new bearings and it was fine. was only a very very slight knock though on mine.
I've since done the bottom end on my glanza twice, both times on that it was too far gone and a new set of bearings didn't save it. The way i saw it was it's £60 for a new set of bearings or £500 for another engine/rebuild. worth trying some bearings first i suppose. If it's knocking bad though i doubt you'll save it (I can't see the video on my MOD computer so cant hear it)
if it is the crank...i'd suggest you get a "used" good condition replacement, get it checked by a machine shop and completely clean your engine and oil pick up/pathways as its likely to have ground up metal in there some where which came from the spun bearings/crank.......maybe even a complete bottom end if you can
reason i say this...it will save you trouble in the long run
you have to check all clearances again too....best to be safe
just changing a bearing will not work
It's all about what's local and most things starlet wise are scarce. I'm not on the mainland u see so gonna cost a bomb postage whatever the scenario will b cheaper to get mine fixed I think. Next oversize is +0.25 is that right?
so ive managed to whip everything off and check mine and it does not look/sound like the problem in JDMfreak's video.
When i wiggled the conrod bearings front to back (same as video) there is no clonking noise however there is a slight wiggle from side to side but id imagine thats normal for a cold engine no?
there is also a scuffing noise coming from the auto flywheel area when i turn the engine but i doubt that would cause the severe noise coming from the sump like shown in my first video.
whats ppls thoughts re: the bottom end being gone?
https://www.youtube.com/watch?v=btUsvrLO534
I'm thinking number one rod isn't right there mate, to much wiggle, while you got the sump off I would take the rod caps off ( remember which one goes where etc,) and check the bearings and the crank check both big and main bearings as its off.
Not so long ago I built my engine, I didn't go down the acl bearing route and plasti gauge stuff, got a good crack still had it polished and used genuine Toyota bearings
Edited by patman
id be taking that apart again its goosed far to much movement there. There is ment to me the tinyest amount of movement i think the max is about 0.45 not something you could feel with your hands. time for another rebuild unfortunatly thats if the crank is any good any more :(
