im just looking at these 6 speed boxes as they came with lsd in them from the factory. The spec of them is below.
C65/C65M
Gear ratios for this transmission.
1st
2nd
3rd
4th
5th
6th
Reverse
Final
3.166
1.904
1.392
1.031
0.815
0.725
3.250
4.312
Differential Options:
  • C65-01A: Open Differential
  • C65-01B: Helical Limited Slip Differential (LSD)
Applications:
C66/C66M
1st
2nd
3rd
4th
5th
6th
Reverse
Final
3.166
1.904
1.310
0.969
0.815
0.725
3.250
3.941
Applications:
  • 2003–2005 Toyota MR2 Spyder with Helical LSD (Europe) (manual mid-engine application)
Any idea if they will fit our 4e engines if the belhousing and shifter linkages are swapped?
From a quick look at Mrs and Elise exige boxes the linkages comes out of the front side of the gearbox rather than the rear
So custom linkage maybe required
Phil
Another option is a guy on facebook sells corolla tsport gearboxes with the lsd and 6th gear from these.
Better 1-5th ratios but a long 6th for cruising and the linkages would be the correct way round
Drive shaft splines are different aswell. If you really want a 6sp box with an lsd you would be better of getting a c160 from a levin 20v, You would still then need to swap the bellhousings over.
Thanks for the replies guys. I wouldn't be running big power only ct9 hybrid on my 4e or the 5e i have. So shredding gears shouldn't be any issue for me.
It sounds like it's a no go though for the size of them and the shafts not fitting.
Cheers
I was hoping done fwd linkages could be fitted to it.
ofcoure it can be swapped over
but the 2002 mr2 i was working on last week hase the levers in same spot as starlet so no need for swapping ha ha
Edited by 5e colin
Cheers
bean, my advice is dont put a ct9 or ct9 hybrid on a 5e....not a good set up
